Correct carb for a 250 six
Moggy
Number of posts : 17
Registration date : 2014-12-25
Post by Moggy on Tue Dec 30, 2014 12:17 pm
The carb on my 250 six is a bit ropy, when the parts store searches for G10 they can only find the 230 motor.
Any idea where the 250 came from? maybe a larger pickup model?
The current carb is I believe a Rochester single barrel.
Moggy.
Number of posts : 11629
Re: Correct carb for a 250 six
Post by donivan65 on Tue Dec 30, 2014 12:21 pm
Rochester Monojets came on the 2nd Gens 1967-70,,,,,,,,when the 250 engines were kind of invented also,,,,,,
Moggy
Post by Moggy on Tue Dec 30, 2014 2:09 pm
Just checked and mine has a Carter YF
Number of posts : 1868
Post by HandiVanMan on Tue Dec 30, 2014 2:31 pm
What year model is your van? The 250 6 cylinder engine was not available in the Chevy G10 & Gmc van until 1967.
Moggy
Post by Moggy on Tue Dec 30, 2014 3:59 pm
This van was owned from new till 2007, at some point the original 230 was replaced with a 250
It has only 7000 miles on it and is a brilliant engine for this van, loads of torque, however I think the carb needs replacing.
Moggy.
Moggy
Post by Moggy on Tue Dec 30, 2014 4:01 pm
The current carb is a Carter YF 1835
Moggy
Post by donivan65 on Tue Dec 30, 2014 4:10 pm
Is that what is stamped on the base????? they normally are 3100-4300 numbered,,,,,is it a manual, electric or automatic choke,,,,is it a Ford Carter Carb?
Moggy
Post by Moggy on Tue Dec 30, 2014 4:30 pm
Hi
Just checked it is a YF 4395S I was quoting the number of the end of the float bowl (1835)
Moggy
Moggy
Post by Moggy on Tue Dec 30, 2014 4:31 pm
Sorry forgot to add it is a manual choke
Post by donivan65 on Tue Dec 30, 2014 7:26 pm
It sure is my favorite carburetor,,,,,,,,
Moggy
Post by Moggy on Wed Dec 31, 2014 12:51 pm
Where can I get one?
Post by donivan65 on Wed Dec 31, 2014 1:02 pm
,,,are you sure you need another carburetor?
kookykrispy
Number of posts : 1456
Post by kookykrispy on Wed Dec 31, 2014 8:53 pm
Rebuild the one you have! They're easy
Moggy
Post by Moggy on Thu Jan 01, 2015 12:57 am
Have a rebuild kit and a core, just looked a bit time consuming, thought it would be easier to buy a new one, then couldn't find any!
Number of posts : 1412
Post by Vantasia on Thu Jan 01, 2015 7:42 am
Many threads on this...if you can't rebuild it or find a good used one to rebuild, there is only one newly made single barrel carb on the market today. Carter, Rochester, Holley, etc..none of them sell new one barrels...only a start-up company in FL called Daytona Parts co. makes a new carb using old reworked Holley molds. They are universal fitment and I bought one, great carb, no issues, fast starts, plenty of power, smooth idle, all you'd expect from a new carb...check out here
http://www.daytonaparts.com/universal-replacement-carburetor.html
PM me if you want to know more....
click the see it in action link for '63 Chevy to see one installed on a 230 engine. BTW, 230 ans 250 are pretty much the same intake, different crank/pistons/head? give it the larger displacement, carb should be the same...
    Current date/time is Mon Jun 25, 2018 12:44 am
