    wide rear wheels
    econorat
    Number of posts: 172
    Registration date: 2008-10-29
    wide rear wheels
    Post by econorat on Fri Mar 27, 2009 8:51 pm
    hi gang,
    I'd love to put some wider rear wheels/tires on my van.
    Picture is the height I'd like but maybe 2 inches wider.
    Anyone done it? How do I raise the rear to clear the fenders?
    Thanks Smile
    Number of posts: 2968
    Registration date: 2008-05-02
    Re: wide rear wheels
    Post by Vanish on Fri Mar 27, 2009 9:00 pm
    What a COOL PICTURE !!!!! WHO IS THAT ??? is that your Van ????
    ,,,Vanish,,,
    '' Be thankful we're not getting all the government we're paying for''............
    MCMLXV
    Post by Guest on Fri Mar 27, 2009 9:11 pm
    That pic is off of my clubs website. One of my clubs members.
    Wide tires like these???? N50x15. Rims are 10x15. Re-arch your springs then add a three inch block on each side.
    you can use air shocks or the Monroe shocks in the above pic.
    Last edited by vanishingbreed on Fri Mar 27, 2009 9:20 pm; edited 2 times in total (Reason for editing : added info.)
    Post by Guest on Fri Mar 27, 2009 9:16 pm
    Post by Guest on Fri Mar 27, 2009 9:23 pm
    you may have to get longer brake lines. I did. Mine were custom made at a hose shop. Don't remember how much they cost.
    Post by Vanish on Fri Mar 27, 2009 9:24 pm
    Mike whats the Deal On the White Van ????????
    ,,,Vanish,,,
    MCMLXV
    Post by Guest on Fri Mar 27, 2009 9:41 pm
    It is a 64. I sold it several months ago
    SIX-FO'
    Number of posts: 240
    Registration date: 2009-02-07
    Post by SIX-FO' on Fri Mar 27, 2009 10:07 pm
    Hey VB, when you added those lift blocks, did you have any problems with your drive shaft angle? I think your van has an awesome stance and I am thimking about adding lift blocks to mine.
    -Ryan
    Post by Guest on Sat Mar 28, 2009 6:13 am
    Nope no problems
    Number of posts: 1234
    Registration date: 2009-01-29
    Post by 67a 100 pickup on Sat Mar 28, 2009 7:29 pm
    VB... Did you have to add a leaf or just re-arch them???
    Post by Guest on Sat Mar 28, 2009 8:12 pm
    yes I did add a leaf The tires I have on it required it because they are so tall. A lower profile tire wouldn't require it.
    Last edited by vanishingbreed on Sat Mar 28, 2009 8:13 pm; edited 1 time in total (Reason for editing : corrected spelling)
    SIX-FO'
    Post by SIX-FO' on Sat Mar 28, 2009 8:49 pm
    Probably a stupid question, but where would I get my springs re-arched? And how much does it cost?
    Post by Guest on Sat Mar 28, 2009 9:27 pm
    I had all of mine, front and rear re-arched, added a spring to each corner and the 3" blocks with new u bolts for $300.00. Any good spring shop can do it for you.
    econorat
    Post by econorat on Sat Mar 28, 2009 9:46 pm
    Awesome job, that's exactly what I want.
    Funny though, when I got the van it was lowered...but I think raised is the way to go with these. Looks killer.
    I have a spring service shop near, will have to check.
    Questions: How do you keep the block from moving, is it bolt through?
    Are these the shocks for the towing option sold by rockauto?
    How do you determine if you need another leaf?
    What rims did you use?
    Boy those Mickey Thompsons must have set you back more than the lift job.
    How is the ride?
    Thanks Smile
    Post by 67a 100 pickup on Sun Mar 29, 2009 6:07 am
    Are those MT 12" or 15" wide?? I'm thinking 30 x 12 R 15 for my pickup. I don't think I can go any wider than 12's since my wheels are only 8 1/2" wide. My fronts are 26" tall, might even get lucky and keep them in the fender wells.
      Current date/time is Wed May 16, 2012 2:44 pm
