Dash Pad options for 2nd Gen G10?
morbank
Number of posts : 161
Post by morbank on Tue Oct 28, 2014 10:23 am
Anyone know if any other Chevys used the same dash pads as a 2nd gen van? The C10 dash pad looks pretty similar.
Number of posts : 766
Re: Dash Pad options for 2nd Gen G10?
Post by panelmanrd on Tue Oct 28, 2014 10:51 am
67/70 chevy van only
morbank
Post by morbank on Tue Oct 28, 2014 12:03 pm
I had a feeling someone was going to say that.
Number of posts : 1391
Post by Vantasia on Tue Oct 28, 2014 12:43 pm
You could recover an old one or fabricate a reasonable looking pad from wood covered with a thin layer of foam and vinyl fabric (Naugahyde). Shape some pine and use a staple gun for the covering, would look real sharp if you do it right. Even a nice finished wood one would look good depending on your interior decor....better than all those holes in the dash! I have seen many custom made pads over the years....
mo_1040
Number of posts : 638
Post by mo_1040 on Tue Oct 28, 2014 3:07 pm
I made mine with fiberglass, I wanted to cover the center speaker hole and use two speakers in the front so I went all the the way to the windshield. Really wasn't to difficult to make. To make a stock looking one would be a lot easier than what I did. I covered the whole dash with tinfoil, ran a strip of oak across the front, added some studs for mounting and started slapping glass. If your planning to add foam and vinyl, it would be easy to make a fiberglass shell/pan to get upholstered doing it this way.
morbank
Post by morbank on Tue Oct 28, 2014 7:50 pm
That pad looks fantastic Mo! I'm fairly crafty so I think I should be able to pull this off. Thanks for the pointers.
Does anyone have any pictures of an original 2nd gen dash pad uninstalled?
Number of posts : 11492
Post by donivan65 on Tue Oct 28, 2014 10:33 pm
I think my buddy paid $300 to have a new one made,,,,,,
I have an old real one,,,,,,it has 7 studs in back and 6 holes up front,,,,,,,it is fiberglass with kind of Styrofoam on the inside
morbank
Post by morbank on Tue Oct 28, 2014 11:09 pm
Thanks for the pics, very helpful! So the inside is soft and the exterior is hard? I always imagined the exterior would be slightly soft padding with a vinyl cover. And does the exterior have a leather texture?
Post by donivan65 on Tue Oct 28, 2014 11:19 pm
The outside is hard fiberglass,,,,,,it did have a wrinkle finish on it, but the paint kind of makes it smooth now,,,,,,,,
Post by Twinpilot001 on Wed Oct 29, 2014 6:14 am
The origional pads were -soft! heat makes them brittle, hard & cracked! on this site is a member - econolines builder-cant remember his name - builds & supplies econo parts for many here!! He is also a upholstery man!!!!!!!!!!!!!!!!!!!!! He will redo ur dash pad for around 100-125 bux - someone will remember his name -contact him!! cheers also most upholstery shops will redo these too. U can also look in utube!!!!!!!!!!!!!!!
morbank
Post by morbank on Wed Oct 29, 2014 2:37 pm
@ Donivan. I see what you mean now. Thanks for the pic.
@ Twin. Thanks for the info! ... Anyone remember who this member is?
back2thewoods
Number of posts : 830
Post by back2thewoods on Thu Oct 30, 2014 5:10 am
that would be fred, I think his last name carrillo? great work
Post by Twinpilot001 on Thu Oct 30, 2014 6:36 am
yes!!!! Hes the -MAN!!!!!!!!!!!!!! cheers
morbank
Post by morbank on Thu Oct 30, 2014 7:57 am
Thanks guys, I sent him a PM. His member name is fmc56 btw.
Number of posts : 1781
Post by Van Halen on Sat Nov 01, 2014 4:56 am
I recovered mine.
morbank
Post by morbank on Sat Nov 01, 2014 10:06 am
Nice soft look Halen! Unfortunately I've got nothing to recover as my pad is M.I.A.
morbank
Post by morbank on Sun Nov 02, 2014 7:28 am
Heard back from Fred, unfortunately he only does Fords...
Anyone have any experience with any upholsterers in the Ventura county or Los Angeles area?
ac95
Number of posts : 24
Registration date : 2015-03-16
Post by ac95 on Mon Mar 16, 2015 11:26 am
panelmanrd wrote:67/70 chevy van only
So the pad will work on a 67 Van?
morbank
Post by morbank on Mon Mar 16, 2015 11:48 am
No, I believe panelmanrd meant that the original 67/70 dash pads are the only dash pads that will work on the 67/70 G-Vans. So the C10 dash pad is a no-go.
kookykrispy
Number of posts : 1452
Post by kookykrispy on Mon Mar 16, 2015 12:02 pm
That is correct, the only dash pad that will fit a 2nd gen chevy/gmc van, is one from a 2nd gen chevy/gmc van. 1967-70 only
ac95
Post by ac95 on Mon Mar 16, 2015 12:13 pm
Thanks for the clarification guys.
Post by Vantasia on Mon Mar 16, 2015 12:19 pm
Like shown, you should be able to make one, try to make a shaped wood core and then cover it with a thin layer of foam padding and then naugahyde vinyl, they sell it at most good fabric shops in many colors and grains, use a staple gun, be creative! They sell small studs with a lag screw on one end that should work for the mounting bolts.
dougtappan
Number of posts : 262
dahboard repair
Post by dougtappan on Mon Mar 16, 2015 3:52 pm
Hey Morbank.....Justdashes.com....I'm serious.
morbank
Post by morbank on Mon Mar 16, 2015 3:59 pm
I thought I looked at them... Do they do custom dashes? I don't see G-10 Vans on their list of dashes they sell. Am I missing something?
    Current date/time is Thu Jan 18, 2018 9:45 am
