stearing wheel trouble
Number of posts : 359
Registration date : 2014-09-26
Post by rocky69rhodes on Wed Oct 22, 2014 2:04 pm
took my steering wheel off to replace turn signal assembly but when I try to put it back on the horn relay sounds and after putting it on if I turn it back an forth the relay sounds to the horn doesn't go off just a low rumble
Number of posts : 11569
Re: stearing wheel trouble
Post by donivan65 on Wed Oct 22, 2014 2:42 pm
Take everything under the horn button off except the nut,,,,,,,,see if your problem goes away,,,,,,jump the horn brush contact to the nut,,,,,,,that should energize the horn relay which will turn on the horn,,,,,,see what you get......
Post by rocky69rhodes on Wed Oct 22, 2014 2:53 pm
ok thank Donivan I will try that
Post by donivan65 on Wed Oct 22, 2014 2:56 pm
so whats the complaint,,,,,,horn don't work ,,,,horn don't sound right,,,,,horn works when it shouldn't,,,,,
Post by rocky69rhodes on Wed Oct 22, 2014 3:26 pm
horn must be broke I will get a replacement and try that all it does is click an I solved the problem of it clicking all the time by cleaning the parts
Post by donivan65 on Wed Oct 22, 2014 3:29 pm
stick a paperclip in the horn relay socket to see if the horn works to eliminate the relay or wiring being bad......
Post by rocky69rhodes on Wed Oct 22, 2014 3:32 pm
about a week ago my neighbors told me my horn went off for about 15 minutes at 4 in the morning an then died
Post by rocky69rhodes on Wed Oct 22, 2014 3:33 pm
ok thanks
Post by donivan65 on Wed Oct 22, 2014 3:39 pm
just don't be pushing the horn button when you stick a paper clip in the socket where the relay goes,,,,horn should blow when you find the 2 correct slots to jump across.....
Post by rocky69rhodes on Wed Oct 22, 2014 3:59 pm
cant find the relay
Post by rocky69rhodes on Wed Oct 22, 2014 4:54 pm
found relay tried every hole horn doesn't work
Post by rocky69rhodes on Wed Oct 22, 2014 6:24 pm
got new horn it works
Number of posts : 1412
Post by Vantasia on Thu Oct 23, 2014 6:18 am
If the horn blasted for 15 mins, probably overheated inside and damaged coil, but at almost 50 years old it was probably on its way out....relay is in back of engine box on these things!
Post by donivan65 on Thu Oct 23, 2014 9:37 pm
relay is under the dash,,,,,,,
Post by rocky69rhodes on Thu Oct 23, 2014 10:20 pm
yes found it thanks
Post by Vantasia on Fri Oct 24, 2014 5:53 am
donivan65 wrote:relay is under the dash,,,,,,,
Is that a 2nd gen thing? its in my doghouse on my 1st Gen.
Post by rocky69rhodes on Fri Oct 24, 2014 6:11 am
I guess it is
Number of posts : 774
Post by panelmanrd on Fri Oct 24, 2014 6:45 am
second gens have a slightly different electrical
the turn signal switch, and the horn relay is different
and located under dash instead of in doghouse
turn signal switch has emergency flasher built in
    Current date/time is Mon Apr 23, 2018 12:14 pm
