diagram for lock
Number of posts : 359
Registration date : 2014-09-26
diagram for lock
Post by rocky69rhodes on Thu Oct 16, 2014 11:38 pm
I need to know how to hook up the bar that goes to the floor on my side cargo doors lock does anyone (Donivan ) have any ideas" />
Number of posts : 1880
Re: diagram for lock
Post by savage on Fri Oct 17, 2014 5:22 am
Theres one for R &,one for the L(not the same),they got clips (that they havn't made in Years)that hold rods on latch. Hopefully Don will post pics.
Number of posts : 1412
Post by Vantasia on Fri Oct 17, 2014 5:38 am
I think the shop manual supplement has exploded views of this...can scan later, but as said, there are clips that hold them to the lock cam lever, hard to find, but many parts vans around, start asking! But I'm sure a working replacement can be made from something...the hardest thing is getting hands inside the door to get to them! Also use an inspection mirror to look at your other doors to see how they attach, front and side should be the same, L + R.
Number of posts : 11628
Post by donivan65 on Fri Oct 17, 2014 9:42 am
Post by donivan65 on Fri Oct 17, 2014 9:47 am
Post by Vantasia on Fri Oct 17, 2014 10:12 am
donivan65 wrote:
So what does one do for the broken or missing clips? Anyway to modify the connection or use a speed nut?
Post by donivan65 on Fri Oct 17, 2014 12:31 pm
If I lost my spare clip. I would try one of these,,,,,,you might find samples of it on your clutch and carburetor linkages,,,,,
Post by rocky69rhodes on Fri Oct 17, 2014 2:42 pm
Thank you so much Donivan I knew you would know
Post by rocky69rhodes on Fri Oct 17, 2014 5:30 pm
success door fixed
morbank
Number of posts : 161
Post by morbank on Thu Mar 05, 2015 8:10 pm
On the topic of side door locks... Anyone else's cargo door locks rattle like crazy? The rods and the latch at the top of my cargo doors vibrate incessantly the moment I start up the motor. I was thinking I might be able to attach a thin plastic washer or rubber band on the rod clips to keep them from rattling around. But I'm not sure how to stop the top latch from moving around. There isn't more than 1/16 of an inch of play so not much room to work with. Anyone have any suggestions?
Post by Twinpilot001 on Thu Mar 05, 2015 9:02 pm
Gm used some fabric looking material that slid over the rods-prevented rattles inside the doors.You might also try some thin hose like fuel line or vac tubing that could slide over the rods or be cut to fit over then & secure with a tie wrap??
morbank
Post by morbank on Thu Mar 05, 2015 10:15 pm
Fabric, interesting. All of the noise in my doors is coming from the top latch and at the bottom of the rods, where they connect to the lock mechanism. The fabric or tubing may help, but I will still need something to tame the top latch... I'll post if I come up with anything that works
Post by donivan65 on Fri Mar 06, 2015 12:37 am
...make sure the wedge side on the ends of the rods faces out to suck the doors in when you turn the handles,,,the vans did come with anti rattle clips that sit down in the square holes the rods go into,,,,,
Post by Vantasia on Fri Mar 06, 2015 7:43 am
Similar to the tube or fuel line idea, I put some plastic split type wire wrap around them, that helped a lot. Then before I paneled, I stuffed some scraps of fiberglass insulation in the doors around the rods and shimmed the top holes with a small aluminum L clip epoxied to the striker hole, stopped all rattle and the doors close tight. The original clips Doni mentioned were long gone, they rust away. I saw over at VCVC some one is selling new striker kits with optional anti rattle clips made from spring steel like the originals. But this won't stop the rods from rattling against the door, wrap them.
morbank
Post by morbank on Fri Mar 06, 2015 9:43 am
Yeah, here's what's left of my rattle clips:
Sounds like the rod wrapping is the way to go. Thanks all.
morbank
Post by morbank on Fri Mar 06, 2015 9:46 am
    Current date/time is Tue Jun 19, 2018 8:36 pm
