Vangoat wrote:Just replaced my tank the other day on my 61 with a modified 69 mustang tank, 20 gal.Used straps from a bronco, cut down, longer strap bolts and 5/8" vent hose. Went right through frame hole no problem. Attached to 1/2" tube with clamp. Don't know if the 1/2" tube just ends up there or if a hose is supposed to come back down to frame like the later models. Anybody know for a 61?
It got to go back down, that's why there are 2 holes there. Otherwise the tank will be venting into the cab, i.e. gas fumes.
The 5/8" fuel hose I tried would not go through the body holes. So I bought 1/2" hose and found it was pretty easy to get it to slide onto the 5/8" tank fitting with some silicone spray.
