Just bought a 1967 van
gkpost
Number of posts : 223
Re: Just bought a 1967 van
Post by gkpost on Thu Feb 05, 2015 6:40 pm
Congrats and welcome ! If you have an early van this is the best site you could be on.
I have a 67 G. I'm no mechanic, without the help I've got from the people on this site, there is no way I would have been able to do half of the things I've done with my van.
Good luck with your van. Take your time, your van is worth it. ~ GK.
Number of posts : 9607
Post by vanny on Thu Feb 05, 2015 7:05 pm
Rocky, you've definitely made it your own! Freedom of expression at it's finest! Dare to be different...if it makes you happy, don't matter what anyone else thinks!!! cheers Very Happy
Number of posts : 359
Registration date : 2014-09-26
Post by rocky69rhodes on Thu Feb 05, 2015 8:48 pm
[img][/img]
Post by rocky69rhodes on Fri Feb 13, 2015 3:27 pm
Post by vanny on Fri Feb 13, 2015 4:32 pm
Rocky, love the cedar planks on the walls! Bet it smells great when you cut it! Nice work! cheers cheers cheers
Post by rocky69rhodes on Fri Feb 13, 2015 5:42 pm
[img][/img]
Number of posts : 11569
Post by donivan65 on Fri Feb 13, 2015 7:34 pm
I'll be at Pik a Part tomorrow if you want some door handles,,,,,,,
Post by rocky69rhodes on Fri Feb 13, 2015 10:20 pm
2 please inside and outside is there a old van there???
Post by donivan65 on Fri Feb 13, 2015 10:27 pm
probably no vans there,,,,,,I got some used side/rear outside handles and bezels you can have,,,,,
if you got some way of getting to Pik a Part around 2 -4 pm tomorrow,,,,,,jump up on my rear bumper and they will be on my vans roof,,,,,,,
Post by rocky69rhodes on Fri Feb 13, 2015 10:59 pm
ok thank you
Post by vanny on Sat Feb 14, 2015 4:34 am
Don, you da man!!!
Post by rocky69rhodes on Sat Feb 14, 2015 12:49 pm
[img][/img]cedar spacers in place speakers mounted
Post by rocky69rhodes on Sat Feb 14, 2015 12:52 pm
[img][/img]
Post by Joe Van on Sat Feb 14, 2015 1:09 pm
rocky69rhodes wrote:" />
"Great Job" Question..!!!..I am thinking the Red Ceder on mine also VERY SOON the same way... Did the boards start out in 8 ft lengths and you cut them down to get that effect or did they come in different lengths..??..I guess what I am trying to say is do you think If I go with the same 8ft boards I can get away with out putting any plywood down first or do you need something behind the cedar boards for support..??..I was thinking screw 4 inch wide strips of plywood on each rib for something to fasten the boards to instead..scratch..And how wide are the boards that you used 3 or 4 inch.??...Thanks..Joe..
Post by rocky69rhodes on Sat Feb 14, 2015 1:12 pm
4 ft lengths an some shorter it comes 15 sq ft to a pack for 30 $ I used 3/8 behind it as I felt 1/4 was to flimsy it is 4 in wide and I have used 4 packs so far an bought 4 more for ceiling hoping to return 1
Post by rocky69rhodes on Sat Feb 14, 2015 1:13 pm
also glued (liquid nails) an screwed it took screws out after 12 hours
Post by Joe Van on Sat Feb 14, 2015 2:31 pm
rocky69rhodes wrote:4 ft lengths an some shorter it comes 15 sq ft to a pack for 30 $ I used 3/8 behind it as I felt 1/4 was to flimsy it is 4 in wide and I have used 4 packs so far an bought 4 more for ceiling hoping to return 1
Thanks for the reply that helps me out alot..!!!. Smile .It looks Really Nice..
Post by vanny on Sat Feb 14, 2015 3:32 pm
Glad you got the speakers squared away. You're doing a great job on those walls!
Post by rocky69rhodes on Sat Feb 14, 2015 6:01 pm
now my side doors lock thanks to Donivan for the handles
Post by donivan65 on Sat Feb 14, 2015 7:31 pm
you better get those brake lights fixed,,,,,,you aint got any,,,,turn signals work,,,,,,
Post by rocky69rhodes on Sat Feb 14, 2015 9:03 pm
Thanks Donivan Have to go to the shop Monday and have them fixed a little dismayed paying 750$ for a new starter wiring and motor mount and not having brake lights
Post by rocky69rhodes on Sun Feb 15, 2015 2:06 pm
" />" />" /> walls done speakers working now on to the ceiling
Post by donivan65 on Sun Feb 15, 2015 6:27 pm
rocky69rhodes wrote:Thanks Donivan Have to go to the shop Monday and have them fixed a little dismayed paying 750$ for a new starter wiring and motor mount and not having brake lights
,,,,,, I think you ought to be a little more than
DISMAYED
Post by donivan65 on Sun Feb 15, 2015 7:02 pm
,,,did you get a new Clutch, pressure plate, throw out bearing, pilot bushing, ring gear, transmission seals,and u joints with that starter,,,,
Post by rocky69rhodes on Sun Feb 15, 2015 7:26 pm
No and Yes I am very disappointed with the mechanic
Last edited by rocky69rhodes on Mon Feb 16, 2015 11:11 pm; edited 2 times in total
    Current date/time is Thu Apr 26, 2018 3:50 pm
