Does anybody know what size rear shackles and bushings I need for my 1st generation Chevy? Beyond that if anybody knows a good online source or them that would be good info too.
Rear leafsping Shackles
ArtVanDelay- Number of posts : 6
Registration date : 2014-04-30
- Number of posts : 12218
Re: Rear leafsping Shackles
oldgoalie- Number of posts : 55
Registration date : 2014-06-04
They are the same ,,,,however,,,,,once in a while you find a 1st Gen with a bigger 1 5/8" bushing in the right front perch,,,,,,,,,,,,,,
Thanks for the info!
I ordered mine by application from a local parts store. The forward bushings came correct but the rubber bushings came 1" in dia. rather than 1&1/8". just ordered the hb930 should fix me up with a little trimming.
Did you get the neoprene with a sleeve or the metal cartridges for the forward ends,,,,,
donivan65 wrote:Did you get the neoprene with a sleeve or the metal cartridges for the forward ends,,,,,
I got the metal cartridge style. They are installed just waiting on the rear bushings.
Do you got a part number, price and source for the metal bushings?
O'Reilly's auto parts got them for me. Came from Rare Parts Inc., Stockton, Ca.. they where about $43 each, part # 35214. They have a web sight and show these by application. They also show the rear bushings but they where only 1" in dia. They are a little pricey, the rears where $6 each. Found those at the place you showed for like $8 for a set of 4. I am sure the fronts are cheaper there also, I haven't looked. I had the pricey ones in my hands and needed to get my van back on the ground, so I used 2 of the front sleeves.
