gas tank sending unit for a 66
ALLZS
Number of posts : 39
Registration date : 2014-05-04
Post by ALLZS on Sat Aug 16, 2014 6:20 am
where can I find a new fuel tank sending unit someone said rock auto had them but I can not find it on there web site ?
Number of posts : 3736
Re: gas tank sending unit for a 66
Post by Digz on Sat Aug 16, 2014 7:03 am
Nothing new for a first gen chevy. Improvise and adapt or have your old one rebuilt. I do not have the part number handy but have one I ordered that is "close" in design but has a 90 Ohm sending unit on it. The guys have the link or addy for a re-builder I'm sure and Don has come up with some aftermarket options also. See what they all say. Finding a good used one is possible but the parts in them are still ancient and tend to be in close to crap condition .
Number of posts : 11492
Post by donivan65 on Sat Aug 16, 2014 11:51 am
I take the guts off a $34 universal 30 ohm sending unit and screw it on our pick up tube,,,,,
Post by donivan65 on Sat Aug 16, 2014 11:59 am
Post by Joe Van on Sat Aug 16, 2014 3:00 pm
"Great Solution" I will be ordering one also hopefully soon..!!!...Doni I did not notice on mine is the Original float assembly Bolted or Tack welded on and what can I use for a screen/filter mine is missing.??..I have to drop the tank down again anyway to put the right O ring in and install my trailer hitch... When my gauge says Full I can still fit 5 more gallons in so something is going on there... I have 2 extra gas gauges and all 3 show a different fuel level..scratch..??? Thanks.....
Xelmon
Number of posts : 343
Post by Xelmon on Sat Aug 16, 2014 6:24 pm
Joe Van wrote:When my gauge says Full I can still fit 5 more gallons in so something is going on there...
I noticed that on mine too, kinda nice how it works though. Below E I have 5 gallons, and above F is also 5 gallons. It's no 30 miles left until bone dry like my Civic, still, gets you a pretty good idea where the fuel level's at.
Post by donivan65 on Sat Aug 16, 2014 8:55 pm
OK,,,,,the gas gauge needs ohms to operate,,,,,,,0 for EMPTY,,,,,,and for FULL,,,,30 for a 1st Gen, 90 for a 2nd Gen,,,,,,,,AND the sending unit gets those all its Ohms from the Right Rear shock absorber and only sends what the float lets through it to the gauge,,,,,,(it only means Ohms is EMPTY or Ohms is FULL) and thats what the gauge shows,,,,so the gauge just does what it is told,,,,,the deal is,,,,measure the resistance of your sending unit,,,,see if it reads 0-30 or 0-90,,,,,,Empty to Full,,,see that the ground wire on the shock absorber is good,,,,,then see if the float is bent correctly so that you got a few gallons left in the tank when it drops down,,,,,you can put the old float on the universal sender,,,,it mounts with a set screw....but they come with long float arms,,,,, you could get a fuel sock for the end of the pick up tube,,,,,,,but an inline fuel filter along the frame will do a good job too.....
    Current date/time is Thu Jan 18, 2018 9:40 am
