    Steering Gear Box
    Steering Gear Box Empty Steering Gear Box
    Post by Guest Wed Jul 30, 2014 4:40 pm
    I have a '64 G10 Panel Van. I have been removing and cleaning the underside of my Van project. Steering box looked like a big grease ball. After cleaning it up and refilling with fluid, it appears to be leaking around the output shaft (pitman arm). Books shows a seal at that end. Anyone have a source for that seal? Local parts stores don't seem to have a clue.
    Thanks.
    DMann2
    Meridian, Idaho
    Number of posts : 12218
    Steering Gear Box Empty Re: Steering Gear Box
    Post by donivan65 Wed Jul 30, 2014 5:43 pm
    I would put grease in it,,,,,,the seal probably is GM 5670325,,,,,,,Napa NOS 11055
    Post by Guest Thu Jul 31, 2014 7:34 am
    Thanks, donivan65. I will run those numbers past the local boys and see what we can come up with.
    Post by Joe Van Fri Aug 01, 2014 3:09 am
    I had the same issue with mine also..!!! Car Quest Auto Parts had it (Donivan's Part Number)  and it is a job to get it out take your time not to damage the shaft I used a angled pick... Smile Steering Gear Box 105_0611Steering Gear Box 105_0612Steering Gear Box 105_0613
    Post by donivan65 Fri Aug 01, 2014 8:40 am
    I would try running grease in there to see if it stays in before messing with that seal,,,,,,,there might be a worn out bushing there causing the problem......
      Current date/time is Fri Apr 19, 2024 8:55 am
