Jeremy Wynn
    power brake booster from summit?
    Jeremy Wynn
    Jeremy Wynn
    Number of posts : 46
    Registration date : 2014-06-30
    power brake booster from summit? Empty power brake booster from summit?
    Post by Jeremy Wynn Wed Jul 23, 2014 9:31 pm
    http://www.summitracing.com/parts/aaz-51-8001/applications/year/1969/make/chevrolet/model/g10-van
    anyone know if this will fit my 69? clearly says it will, is it a bolt on thing or is their factory brackets or something that my van does not have since it came without power brakes?
    Jeremy Wynn
    Jeremy Wynn
    power brake booster from summit? Empty Re: power brake booster from summit?
    Post by Jeremy Wynn Wed Jul 23, 2014 9:33 pm
    Number of posts : 12218
    Post by donivan65 Wed Jul 23, 2014 11:17 pm
    no way,,,,,,there is no room for that thing between the radiator and grille,,,,,,,,
    power brake booster from summit? Nodoor17
    Jeremy Wynn
    Jeremy Wynn
    Post by Jeremy Wynn Thu Jul 24, 2014 9:47 am
    donivan65 wrote:no way,,,,,,there is no room for that thing between the radiator and grille,,,,,,,,
    Thats what I was thinking, why in the world would summit say that it fits? They even have the link on the page to check if it will fit and it lists all the g van models and says it fits... I understand ebay saying dam near everything fits a g10 when you search but summit, come on.
    Number of posts : 801
    Post by panelmanrd Thu Jul 24, 2014 10:51 am
    summit does no reaserch of their own, they count on
    others to do this, if it is printed somewhere they think
    its true.
    Post by donivan65 Thu Jul 24, 2014 11:16 am
    ,,,,in our World,,,G 10 is our vans,,,,,,in the rest of the World,,,,,C 10 and Step Vans looks close enough for them....and they don't realize a 1970 van is nothing like a 1971.........
    Post by Joe Van Thu Jul 24, 2014 3:00 pm
    "Power Brakes" & "Power Steering" sounds Nice but once you get use not having them and as light as theses Vans are there "Not Bad" at all to drive with out either one..!!!...JMO.. Smile ..
    Post by donivan65 Thu Jul 24, 2014 3:32 pm
    We do have power brakes on some of our vans,,,,,,,using the little hot rod Vacuum booster set up,,,,,RipVanArkie used the 90 degree Ford/Dodge set up and mounted it across the front of the radiator,,,,,,M1D extended the brake pedal rod and put it under the drivers seat under the van......these vans did come with power brakes,,,,,,,but they only powered 1 brake line....and we need a 2 line system.....
    Number of posts : 1778
    Post by m1dadio Thu Jul 24, 2014 6:58 pm
    what Don said
    power brake booster from summit? Dscn0310
    power brake booster from summit? 00110
    power brake booster from summit? 00210
    m1D
    Post by Twinpilot001 Thu Jul 24, 2014 7:37 pm
    Post by donivan65 Thu Jul 24, 2014 9:50 pm
    Here is our brake set up,,,,,,you cant move the pedal and the master cylinder sits up against the radiator,,,,,,,the master cylinder sits up against the floor,,,,,,there is no room for a vacuum booster which fits between the pedal and master cylinder....
    power brake booster from summit? Repair39
    power brake booster from summit? Repair40
    Post by Digz Fri Jul 25, 2014 3:34 am
    Set up straight back, this is as close to the original mount as you can get. Blows away the stock radiator position and makes installing a normal sway bar impossible.
    power brake booster from summit? Mc_clo10
    Jeremy Wynn
    Jeremy Wynn
    Post by Jeremy Wynn Fri Jul 25, 2014 9:10 am
    Digz wrote:Set up straight back, this is as close to the original mount as you can get. Blows away the stock radiator position and makes installing a normal sway bar impossible.
    Do you have any more pictures of this setup? Radiator position ? stock sway bar won't work? did you use an aftermarket in it's place?
    Post by Digz Fri Jul 25, 2014 3:42 pm
    This pic is from a project that is ever changing in ideas. Nothing is finished and all is apt to change. I have moved an engine back 14", and cobbled a swaybar from a Plymouth Arrow PU in mounted weird and backwards. At this time I want to ditch the air ride stuff and get a swaybar in where it belongs and real springs. When I get the time to mess with it I am going to try making a bell crank set up that will point the MC and booster to the front making a 180 turn. I just posted this to show how bad it can be to keep stock locations on some critical parts.
    power brake booster from summit? Ride_h10
    I'd put this in the "Kids Don't Try This At Home" catagory.
    Jeremy Wynn
    Jeremy Wynn
    Post by Jeremy Wynn Fri Jul 25, 2014 4:30 pm
    Digz wrote:This pic is from a project that is ever changing in ideas. Nothing is finished and all is apt to change. I have moved an engine back 14", and cobbled a swaybar from a Plymouth Arrow PU in mounted weird and backwards. At this time I want to ditch the air ride stuff and get a swaybar in where it belongs and real springs. When I get the time to mess with it I am going to try making a bell crank set up that will point the MC and booster to the front making a 180 turn. I just posted this to show how bad it can be to keep stock locations on some critical parts.
    Gotcha, kids def don't try this at home HA! Way more than I will be doing. I can't find time to hardly work on it, going to try later tonight for a few hours
      Current date/time is Thu Mar 28, 2024 11:46 pm
