65' chassis swap
Number of posts : 171
Re: 65' chassis swap
Post by wirepuller on Wed Apr 08, 2015 11:21 am
Sweet fabrication!
I really like how you inverted the R&P. I hope you don't mind if I adapt that idea to my project.
WP
66e100pu
Number of posts : 147
Post by 66e100pu on Wed Apr 08, 2015 11:28 am
suicideking wrote:
66e100pu wrote:I have to mount an Isuzu box in a similar manner, but I haven't been able to locate the right spline to DD u-joints. Do you remember where you found them; part #, spline count, or anything else that might help me locate a set? Appreciate the help!
Jim
The spline is specific to a Chrysler application. The ones I have were made by borgeson but sold through SO-CAL speed shop. I took my box in and stabbed it in the display until I found the right ones. Sorry I don't have a part number for you.
Thanks for the reply - I will have to drag the box in and see if So-Cal has what I need.
suicideking
Number of posts : 68
Post by suicideking on Wed Apr 08, 2015 1:19 pm
wirepuller wrote:Sweet fabrication!
WP
Not at all in fact I have the patterns I could email if you are interest in having them water jetted like I did. The design incorporates a mounting rail for a lower splash pan as well.
PM if interested.
homebrew
Number of posts : 70
Registration date : 2013-04-02
Post by homebrew on Mon Apr 13, 2015 6:01 pm
Dude! That is sick! Very nice work!
Crusty Nova
Number of posts : 11
Post by Crusty Nova on Thu Apr 23, 2015 4:57 am
more details of steering and front suspension would be awesome. sharing your cad drawings for water jet pieces even more awesome
Number of posts : 146
Registration date : 2011-02-01
Post by Jay 13 on Thu Apr 23, 2015 4:27 pm
looking good, keep it up
kookykrispy
Number of posts : 1456
Post by kookykrispy on Fri Jul 10, 2015 1:25 am
Holy shit! This build is freakin crazy!!
Number of posts : 326
Post by jimthefred on Fri Jul 10, 2015 1:19 pm
I am Loving this build! Sweet Van!!
suicideking
Post by suicideking on Wed Aug 19, 2015 8:48 pm
I feel like the chassis is near complete, now on to the body work. Tried to pull most of the heavy dents, then some filler and skim coat to finish. Making some real progress
suicideking
Post by suicideking on Sun Aug 23, 2015 12:45 pm
the last owner did a butcher job on most of the body regrettably. this lower panel is a good example of the care that was taken during the prior resto. I decided to replace the panel outright vs trying to re-repair this panel.
I found a roll panel from a 1967 chevy truck fit fairly close in size and shape...upside down. the panel had too much bow so I had to cut it and work in halves. cut out my new frame rails to leave a space to put my bumper at some point, and rolled a bead into the upper portion to match the existing look.
[/url]
the final panel will have some trim panels around the frame rail to clean that area up. I didn't run the bead all the way across so it will look well different then the original sheet metal but clean and straight I hope." />
Number of posts : 3754
Post by Digz on Sun Aug 23, 2015 2:04 pm
That's looking real good! I ran into something like that on the front roll pan, prior work had it flat.. did the 2 piece thing to get some the curve and lines back.
suicideking
Post by suicideking on Thu Feb 11, 2016 6:46 pm
This is how the trim pieces ended up. rolled them to the same radius and used some aluminum 1/8 rivets to finish it up.
    Current date/time is Sat May 26, 2018 8:16 am
