12 & 10 bolt rear disc break kits
Bear
Number of posts : 849
Post by Bear on Sat Jul 12, 2014 1:19 pm
i think i got a line on a guy like m-1 d who makes disk break brackets that fit rear axles he got them for hat type roters and e-style brake calperes. they start a 180.00 + 12.00 shipping and a extra 30.00 to get them power coated in black when i get more info i will post it
Number of posts : 1212
Re: 12 & 10 bolt rear disc break kits
Post by Space Truckin on Sat Jul 12, 2014 1:26 pm
I am in, will it also come w parts required?
Bear
Post by Bear on Sat Jul 12, 2014 1:28 pm
yes as far as i know it will
Post by Space Truckin on Sat Jul 12, 2014 1:29 pm
Keep us posted  santa
diamond dave
Number of posts : 565
Post by diamond dave on Sat Jul 12, 2014 7:46 pm
speedwaymotors.com has been selling universal rear disc kits for years. theyre pretty cheap for the whole kit.
Bear
Post by Bear on Sun Jul 13, 2014 2:42 pm
thanks dave, looks like this is a bust he only makes e-break for 6-lug not 5 lug will work for me on my 4x4 van
Number of posts : 774
Post by panelmanrd on Sun Jul 13, 2014 10:04 pm
This disc brake kit is for 6 Lugers right? If so has anyone heard what vehicle the rotors are from?
diamond dave
Post by diamond dave on Mon Jul 14, 2014 4:20 am
Probably uses hat rotors from a trailblazer.
diamond dave
Post by diamond dave on Mon Jul 14, 2014 4:23 am
So, you need 6 lug? Not 5?
diamond dave
Post by diamond dave on Mon Jul 14, 2014 4:24 am
Scratch the trailblazer idea. They're metric.
Post by panelmanrd on Mon Jul 14, 2014 6:40 am
just trying to figure out what rotor the 6 lug rear is using
so it can be adapted to the front using a bracket similar to
the ones M1dadio is making.
Bear
Post by Bear on Mon Jul 14, 2014 7:22 am
i will find out and let you know i,m buying a set for my 4x4 van bulid
Post by panelmanrd on Mon Jul 14, 2014 10:47 am
ok
joyrde
Number of posts : 26
Registration date : 2009-03-12
Post by joyrde on Fri Dec 19, 2014 5:13 am
I have rear disc brakes on my 2nd Gen. Modified from '85 - '90 Cadillac Edrado/Toronado . . work GREAT. . M1D installed a complete Firebird (??) disc brake rear end.
This is a page I put together, so I could remember what I did . . . the page and its contents are not meant to be instructional,or recommendations - - - just a record for me. Most everything on the page is based in the work & experiences of others.
BTW - - - the system works GREAT . . . stops straight. Under normal braking, the pedal pressure is about the same ad the 4 wheel drum was. Under hard braking the pedal pressure requires more leg, but stops on a dime!!!
http://www.angelfire.com/wv/joyrde/vanstuff/brakes/VanDiscBrakes1.html
For the complete 4 wheel disc I used all new parts. As for difficulty, brakes are not something that should be undertaken by folks who are not properly trained. I am a retired ASE Master Tech, with 45 years of experience. As for cost, with the machine work, I have close to $1,000.00 in the complete set-up.
Post by Space Truckin on Fri Dec 19, 2014 5:33 am
What a comprehensive write up, LOVE it!!! Almost makes me feel as if I could do it?
Number of posts : 1732
Post by m1dadio on Sat Dec 20, 2014 8:31 am
Yes rear disc brake kits have been availible for 10 bolt and 12 bolt rear ends forever.
Just a reminder, many of us allready know. You get what you pay for when it comes to the one kit fits all made in china disc brake kits. Look into the source of the kits components before you buy.
Vanner68 has discovered my brackets fit onto to G20 spindles. He is currently working on finding a rotor and caliper set up that will work together for the G20. I don't know where hes at with it and I don't know anything else about the G20
M1D
    Current date/time is Sat Apr 21, 2018 7:54 pm
