Rear leafsping Shackles
ArtVanDelay
Number of posts : 6
Registration date : 2014-04-30
Post by ArtVanDelay on Mon Jun 23, 2014 3:57 pm
Does anybody know what size rear shackles and bushings I need for my 1st generation Chevy? Beyond that if anybody knows a good online source or them that would be good info too.
Number of posts : 11492
Re: Rear leafsping Shackles
Post by donivan65 on Mon Jun 23, 2014 4:40 pm
Post by donivan65 on Mon Jun 23, 2014 4:45 pm
Post by donivan65 on Mon Jun 23, 2014 6:06 pm
oldgoalie
Number of posts : 55
Registration date : 2014-06-04
Post by oldgoalie on Mon Sep 08, 2014 6:37 pm
donivan65 wrote:
are the front and rear the same?
Post by donivan65 on Mon Sep 08, 2014 8:12 pm
They are the same ,,,,however,,,,,once in a while you find a 1st Gen with a bigger 1 5/8" bushing in the right front perch,,,,,,,,,,,,,,
oldgoalie
Post by oldgoalie on Sat Sep 13, 2014 7:40 pm
Thanks for the info!
I ordered mine by application from a local parts store. The forward bushings came correct but the rubber bushings came 1" in dia. rather than 1&1/8". just ordered the hb930 should fix me up with a little trimming.
Post by donivan65 on Sat Sep 13, 2014 8:13 pm
Did you get the neoprene with a sleeve or the metal cartridges for the forward ends,,,,,
oldgoalie
Post by oldgoalie on Sat Sep 13, 2014 8:34 pm
donivan65 wrote:Did you get the neoprene with a sleeve or the metal cartridges for the forward ends,,,,,
I got the metal cartridge style. They are installed just waiting on the rear bushings.
Post by donivan65 on Sun Sep 14, 2014 11:55 am
Do you got a part number, price and source for the metal bushings?
oldgoalie
Post by oldgoalie on Sun Sep 14, 2014 4:46 pm
O'Reilly's auto parts got them for me. Came from Rare Parts Inc., Stockton, Ca.. they where about $43 each, part # 35214. They have a web sight and show these by application. They also show the rear bushings but they where only 1" in dia. They are a little pricey, the rears where $6 each. Found those at the place you showed for like $8 for a set of 4. I am sure the fronts are cheaper there also, I haven't looked. I had the pricey ones in my hands and needed to get my van back on the ground, so I used 2 of the front sleeves.
    Current date/time is Thu Jan 18, 2018 9:23 am
