+9
Old Skool
cali2chitown
Devo
FCC
13 posters
    King pin kit on Macs...
    FCC
    FCC
    Number of posts : 295
    King pin kit on Macs... Empty King pin kit on Macs...
    Post by FCC Thu Jun 19, 2014 3:22 pm
    It lists it as "Correctly made, USA manufacture."
    Has this been confirmed? The engrish has me concerned...
    http://www.macsautoparts.com/ford_econoline/king-pin-and-bushing-kit-4-91-long-e100.html
    Number of posts : 12218
    King pin kit on Macs... Empty Re: King pin kit on Macs...
    Post by donivan65 Thu Jun 19, 2014 3:28 pm
    it says bushing must be reamed,,,,,,,are you ready for that?
    FCC
    FCC
    Post by FCC Thu Jun 19, 2014 5:29 pm
    I'm not worried about the reaming. I suppose I can have a shop manage that. I'm talking about the depth of the set pin slot. .644 vs .662
    Number of posts : 2198
    Post by EconoUSAparts Thu Jun 19, 2014 7:04 pm
    If it's wrong, flip em and have a shop cut a new groove. Just stay away from TRW. Those for sure are bad.
    Number of posts : 2086
    Post by Seth G Thu Jun 19, 2014 7:22 pm
    FCC
    FCC
    Post by FCC Thu Jun 19, 2014 10:04 pm
    I'm going to call them tomorrow. Just to find out what that means.
    Devo
    Devo
    Number of posts : 32
    Registration date : 2014-06-09
    Post by Devo Fri Jun 20, 2014 12:08 am
    this thread is perfect timing. I'm very interested in doing the same job.
    Post by EconoUSAparts Fri Jun 20, 2014 2:52 am
    Moog should be good.
    Number of posts : 1747
    Post by econopoor Fri Jun 20, 2014 10:49 am
    Moog can be cut wrong as well. It's hit or miss with them. Trayer is the company that has been cutting them wrong. They are a supplier. When Moog made their own pins they made them right. Now the are buying them from Trayer and Trayer makes them wrong. Most companies have been buying from Trayer for years. Trayer has been told they are making them wrong and refuse to do anything about it. You can have them recut to the correct dimension or drill out the axle to the incorrect size and make an oversize locking pin. Once you drill the axle you can never go back to the correct pin. I'm not sure but I think the Speedway pins were correct but I think they were the 61-63 type. Speedway pins were made to use Econo spindles on their tube front axles for their T-bucket kits. Speedway was sold a few years ago so I'm not sure what's going on with their pins not. They could be buying them now.
    Post by Seth G Fri Jun 20, 2014 12:35 pm
    That's disappointing about Moog, I may order a set just to measure them. Would definitely be worth the extra $35 or whatever dif+shipping is to get a correctly made set, assuming the Mac pins are right...  scratch
    FCC
    FCC
    Post by FCC Fri Jun 20, 2014 1:00 pm
    Ok. good news.
    The operator on the tech line found notes that stated that these are indeed ground to the "correct shallow depth".
    Boom.
    All things considered, its probably more cost effective to go this route than roll the dice and have to spend more $ and time on getting them corrected.
    cali2chitown
    cali2chitown
    Number of posts : 188
    Post by cali2chitown Fri Jun 20, 2014 2:11 pm
    I ordered the ones from rockauto and they worked great and the price was pretty good too.
    https://www.rockauto.com/catalog/x,carcode,1441351,parttype,7340
    Old Skool
    Number of posts : 1306
    Post by Old Skool Sat Jun 21, 2014 1:14 am
    In regards to "REAMING" the bushings its or has been a way of sizing and aligning them into each other using a reamer for at least or over a hundred years or so!!!
     No matter if you hone them or use an adjustable reamer ALL the bushings must be fit to the OD of the pin and so ALL of them are undersized in the box. The bushings need to align perfectly to each other and no other way to it.
      Having owned an automotive machine shop I used both methods for years and using the Sunnen hone did not leave any gouges or low spots as the reamer does. Its worth the money to have them honed.
      Regards to all the conversations and gazillion threads and posts regarding the bad cuts,,, I just assume they are all bad no matter who promises you they are cut correctly. For as touchy as ruining an axle can be I just order them re cut from Ted,, no fuss, no muss, done deal and RE-GROUND not re cut.  Just got two more sets from him and all is perfect...
    Vic
    Number of posts : 14774
    Post by vanny Sat Jun 21, 2014 3:21 am
    Vic, do you have Ted's contact info?
    Thanks in advance!
    FCC
    FCC
    Post by FCC Sat Jun 21, 2014 3:40 am
    I had asked about getting a set from Ted and thought I was told that I would have to mail him a set and wait. Is this the case, or does he 'stock' them?
    Old Skool
    Post by Old Skool Sat Jun 21, 2014 9:37 am
    Here you go,,  usually you simply need to send him yours,,, email him and talk to him,,,
    vic
    I have one set of 64/67 Econoline kingpins with new correct grind for locking pin, $115 including shipping.
    Ted Johns Woodinville, Washington
    __._,_.___
    Posted by: "Ted Johns" <ted@for-d.com>
    Post by donivan65 Sat Jun 21, 2014 11:41 am
    ...on my break,,,,,,I could go over to C&G, which is in the next town over, and measure exactly what they got,,,,,,,and what is different about the 61-63 kingpins?
    King pin kit on Macs... Kingpi10
    King pin kit on Macs... Kingpi11
    Old Skool
    Post by Old Skool Mon Jun 23, 2014 10:06 am
    I wouldn't bother as I have not heard of a good set yet,, other than used ones you just pulled out. Seems like a lot of work to TRY AND FIND a good set. LOL...... If you have Ted re grind on the other side there is NO doubt.  If you can find a good set that would be great....
      The "EARLY" pins (61-63),,, were much different than the picture you posted above.  The pins were longer in length and sealed with large O-rings on both the top and the bottom. They were greased by zirk fittings that were drilled and tapped into each side of each spindle end for each of the two bushings. The ones above in your picture using shorter pins and greased with screw in end caps that had the zirc fittings in them with the bushings DESIGNED TO have the grease enter them from the caps. The early bushings with a diamond shaped entry hole that matched the zirck fitting side placements in the spindle ends. So also, the bushings are different than each other,,, (DUH,,,
      There were NO OVER SIZED LATE PINS available HOWEVER they were available in .010 over sized in the early pins only.  SO,,,,,  this means you can make an oversized late pin out of an early over sized pin.  To do this, (to save a ruined axle, duh),,,,  you can cut the ends off of the early pin in order to match the late pin length, and then cut a entry groove into the late bushings in order for the grease to be able to enter from the caps.
     ALL BUSHINGS are made under sized on purpose so that you can hone them to the correct size and also align them at the same time...
    vic
    FCC
    FCC
    Post by FCC Mon Jun 23, 2014 11:12 am
    I have a set coming from Macs, as part of a larger order. I will report back with the findings.
    I asked a question on my Gallery page, but will ask again here. What does it mean when my passenger side spindle moved up and down when I pumped grease into it. The driver side did not. Worn bearing?
    Post by donivan65 Mon Jun 23, 2014 11:15 am
    ,,,or someone did not put the correct free play shims in it,,,,,
    FCC
    FCC
    Post by FCC Mon Jun 23, 2014 11:18 am
    wait a cotton pickin minute.. there are shims in the mix?! Why haven't I heard reference to these 'free play shims' until now? are these in the typical king pin kit?
    Post by donivan65 Mon Jun 23, 2014 11:28 am
    Look up at my picture,,,,,,those 4 big silver washers are shims that go on top of the axle over the kingpin shaft, to tighten up the spindle,,,,,I would say if you look at where the bottom of the upper bushing sits above the axle, that should be like less than .005,,,,,,otherwise the spindle slides up and down on the kingpin shaft,,,,
    Post by donivan65 Mon Jun 23, 2014 11:34 am
    King pin kit on Macs... Shims10
    Old Skool
    Post by Old Skool Mon Jun 23, 2014 11:43 am
    All the kits have them,, however the spindles are or usually always are worn and its difficult to install them unless you take a file and dress that worn area down flush again. When I install them I take a file and dress that area down until its all flat again.  The shims are exactly that shims,,, the weight of the vehicle is supposed to bear down on the bearings and the shims to take out the slack. When you take yours apart you should see what I am explaining.
     If when you grease it with no load on it and it raises the spindle that would indicate to me that the shims and or the support bearings are worn out and there is free play.
    vic
    Post by donivan65 Mon Jun 23, 2014 11:56 am
    ...I guess the real question is, did someone just do kingpins in that axle,,,,
      Current date/time is Mon Mar 18, 2024 10:12 pm
