replacment swaybar end links
Number of posts : 1688
Re: replacment swaybar end links
Post by westcoastvanner on Thu Aug 21, 2014 6:42 am
Thanks!
Number of posts : 8061
Post by dix on Thu Aug 21, 2014 3:23 am
a100 /08 would be the same end links
Post by westcoastvanner on Wed Aug 20, 2014 6:18 pm
How about for Dodge A100?
lws67
Number of posts : 187
Post by lws67 on Wed Aug 20, 2014 4:55 pm
elijahgray wrote:Suggestions or part numbers for the front swaybar frame mount bushings??
Thanks
I used Energy Suspension sway bar frame mount bushings similar (if not in fact the same) as these from Summit Racing, they come with new brackets, you can also get them in red and with a zerk fitting to lube them if you like. I can't remember the exact part number, but I recall we have 3/4" diameter sway bars, and all you need to do is measure the mount studs center to center to make sure you get the right ones. Cool
http://www.ebay.com/itm/Energy-Suspension-Bushings-Front-Rear-Sway-Bar-Polyurethane-Black-3-4-19mm-Dia-/331279510701?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d21cc2cad&vxp=mtr
lws67
Post by lws67 on Sun Aug 10, 2014 12:38 pm
Go to the Rock Auto website and search for those Ford models. A bunch to choose from. I used Deeza brand links, they are just a tad shorter but otherwise fit perfect and all works fine.
elijahgray
Number of posts : 5
Registration date : 2014-02-01
Post by elijahgray on Tue Jul 29, 2014 9:25 pm
Thanks
Post by dix on Fri May 30, 2014 6:25 pm
a perfect fit 1980-1996 ford f-250 or f-350 swaybar end link
ford part # is 2652071
    Current date/time is Thu Jan 17, 2019 1:01 pm
