New Shocks
Number of posts : 2374
Registration date : 2014-04-15
New Shocks
Post by weirdbeard on Wed Apr 30, 2014 2:38 pm
I need to put some new shocks on my 1964 E-100 and wanted to see what you guys recommend and the cost. Thanks.
Number of posts : 1841
Re: New Shocks
Post by Seth G on Wed Apr 30, 2014 6:23 pm
Be advised, the top bolt(through sleeve in frame) on the rears can be a complete pita. Both of mine were rusted/seized into the sleeve, I got them eventually through much trial and effort but they sucked. I hope you don't run into that. I went with cheapo monroes, but in hinesight I think that was a mistake. Next time I'll get some better coil over types.
Number of posts : 1741
Re: New Shocks
Post by econopoor on Wed Apr 30, 2014 6:30 pm
I have KYB Gas Adjust on my 61 pickup and was really impressed when I switched them from the old shocks that were on it when I bought it. Even my wife noticed the difference. I think they were about $36 each on Rock Auto.
Duane in Tennessee.
Re: New Shocks
Post by Guest on Thu May 01, 2014 9:17 am
I'm running KYB's on both of mine ... but be aware the fronts may need a BFH to install as the crowns are too close to the flanges and they will likely require adjustment as they might smack the mountings ...
Re: New Shocks
Post by Twinpilot001 on Thu May 01, 2014 11:46 am
Monroe or - Gabriel =Overloads!!!!!!!!!!!!!!!!!!!!cheers
cali2chitown
Number of posts : 187
Re: New Shocks
Post by cali2chitown on Thu May 01, 2014 2:23 pm
I had no problems getting the upper bolt off on the rear shocks but 1 of my bolts going through the frame was bent. These probably aren't available anymore are they?
eric67vanpkup
Number of posts : 85
Registration date : 2010-12-07
new-shocks
Post by eric67vanpkup on Thu May 01, 2014 5:01 pm
I am running Gabriels front and rear.
Re: New Shocks
Post by Seth G on Thu May 01, 2014 7:03 pm
grade 8 or better bolt w/shank will do.
FCC
Number of posts : 295
Re: New Shocks
Post by FCC on Fri May 02, 2014 9:19 am
what are you guys with lowered vans using for shocks? Is there concern of bottoming if you lower and use up part of the travel?
Number of posts : 1303
Re: New Shocks
Post by uante on Tue Sep 23, 2014 6:41 am
My ride is super bouncy soft...will just new Monroe or Gabriel shocks stiffen it up noticeably?
Re: New Shocks
Post by Twinpilot001 on Tue Sep 23, 2014 7:37 am
yes - be amazed!!07:36:15 cheers I always try & put coil assist shocks on all my stuff !!
Re: New Shocks
    Current date/time is Mon Feb 19, 2018 7:41 pm
