+6
BADBADGER
mattimuss
BoneMan
Schoessow
10 posters
    intake manifold for a 318
    Schoessow
    Schoessow
    Number of posts : 16
    Registration date : 2012-07-30
    intake manifold for a 318 Empty intake manifold for a 318
    Post by Schoessow Mon Apr 14, 2014 5:08 pm
    Intake manifold for a 1969 Dodge Van A108 318 eng.
    Well, I ran into a snag on my eng. rebuild project.  There is a big crack under the heat shield on the chock side of my intake manifold.  Any ideas on a new after market manifold for this old girl?  It seems everything I look at is a four barrel set up.  I want to keep the two barrel.  Any of you fellows out there got any ideas for me?  I would appreciate it.  Dennis
    Number of posts : 8728
    intake manifold for a 318 Empty Re: intake manifold for a 318
    Post by dix Mon Apr 14, 2014 6:30 pm
    did you try craigslist if so try under different titles
    mopar
    dodge
    plymouth
    chrysler
    Number of posts : 2036
    Post by dodge man Mon Apr 14, 2014 7:32 pm
    i through mine away when i went to a 4 brl. you should be able to get it tig welded,,
    BoneMan
    BoneMan
    Number of posts : 169
    Registration date : 2011-06-23
    Post by BoneMan Mon Apr 14, 2014 7:40 pm
    For an original 2 barrel manifold, the Antelope (or other) pick-n-pull might have what you want for a decent price.  I think they get about $40 for a v8 intake.
    Antelope inventory by year.
    (hope the link works ok)
    http://row52.com/Search?Page=1&MakeId=117&ModelId=0&Year=&SortDirection=asc&Distance=50&ZipCode=&Sort=Year&HasImage=&HasComment=&locationId=39
    4-barrel is a whole nuther can of $worms$.  study     alien
    mattimuss
    mattimuss
    Number of posts : 205
    Post by mattimuss Tue Apr 15, 2014 7:11 am
    I got two, PM me...
    BADBADGER
    BADBADGER
    Number of posts : 246
    intake manifold for a 318 Empty intake manifold 318
    Post by BADBADGER Wed Apr 16, 2014 9:09 pm
    Maybe this should go under a new topic however, i am going to upgrade to 4 bbl set up and am looking at the edelbrock manifold. wanted to know what others have used and has any one used an air gap manifold? Dont know if the manifold carb and air cleaner will fit in the dog box.
    thanks
    BillyBlaze
    BillyBlaze
    Number of posts : 114
    Registration date : 2013-08-15
    Post by BillyBlaze Thu Apr 17, 2014 1:10 pm
    Hit me up with a PM I have the intake off my 318 that i am swapping out if you are still in need. have everything from head up even if need carb/filter and crap.
    Post by dix Thu Apr 17, 2014 1:47 pm
    yes everything does fit but it's tight, find a aircleaner with a down drop offset. BUT if you are doing the swap you want to entertain swaping the exhaust manifold as well  unless you are already  running headers... (MORE AIR AND GAS GOING IN NEEDS MORE ROOM OUT.)
    kookykrispy
    kookykrispy
    Number of posts : 1533
    Post by kookykrispy Thu Apr 17, 2014 2:52 pm
    Number of posts : 1148
    Post by jkr Thu Apr 17, 2014 3:15 pm
    even politicaly correct by year. no egr to leak
    dodge A-108
    dodge A-108
    Number of posts : 67
    Post by dodge A-108 Sat Nov 22, 2014 3:59 pm
    BADBADGER wrote:Maybe this should go under a new topic however, i am going to upgrade to  4 bbl set up and am looking at the edelbrock manifold. wanted to know what others have used and has any one used an air gap manifold? Dont know if the manifold carb and air cleaner will fit in the dog box.
    im running a offy 360 equaflow 4bbl intake with a carter AFB. but if I had it to do again the edelbrock air gap is a good choice, as it helps with heat soak inherent with our vans
    thanks
      Current date/time is Thu Apr 18, 2024 10:58 pm
