kookykrispy
64chevy
    NEW -HEI=6 cyl type---chev
    NEW  -HEI=6 cyl type---chev Empty NEW -HEI=6 cyl type---chev
    Post by Twinpilot001 Thu Feb 27, 2014 6:52 am
    64chevy
    64chevy
    Number of posts : 364
    NEW  -HEI=6 cyl type---chev Empty Re: NEW -HEI=6 cyl type---chev
    Post by 64chevy Thu Feb 27, 2014 7:00 am
    These Chinese Skip White HEI's don't seem to have a very good track record from the postings I've read. I think your better off with a used GM one from a junkyard that you can get parts for at most any auto part stores.
    Post by Twinpilot001 Thu Feb 27, 2014 7:04 am
    have not used this from skip -jhave no idea on durability?? yet everything ive bought from him has worked well!! Chev stroker kits, cam kits, intakes, V-8 dizzysect -just never used any 6 cyl stuff!! Im just looking @ price of a NEW unit - V/S used stuff too.
    kookykrispy
    kookykrispy
    Number of posts : 1533
    Post by kookykrispy Thu Feb 27, 2014 9:28 am
    I've bought two of the HEI's for inline 6 cylinders off ebay.  They worked wonderfully.  One is still installed in my wikivan that I drive everyday.  Its been there for a few years so far with no problems.  Excellent upgrade from the crappy points stuff.
    Skip white is a good seller and stands behind his stuff.  I've bought a bunch of stuff from him, so I can personally attest he is a good guy to deal with.  If you got a bad HEI, send it back and he'll replace it no problems.
    The only issue with the large cap HEI is that they take up alot of room in the doghouse.  It fits, but it is tight to the wall in a 1st gen doghouse.  You will also need different plug wires, so budget for new wires, and you will need to do a little re-wiring for the HEI to eliminate the points style resistor wire in the stock van's wiring.
    Assuming you could even find a chevy inline six at a junkyard, chances are the used HEI would probably cost you almost as much as buying a new one off ebay.
    Number of posts : 801
    Post by panelmanrd Thu Feb 27, 2014 10:45 am
    I got one from him a few years ago and had to replace the pick-up
    coil to get it to work, was cheaper and faster to just fix it.
    diamond dave
    diamond dave
    Number of posts : 565
    Post by diamond dave Mon Mar 31, 2014 10:08 pm
    mine has a new tune and points now, but it would be nice not to have to worry about ignition parts in the future. when using this dizzy, do they recommend that you change to a different plug to compensate for the hotter coil?
    Xelmon
    Xelmon
    Number of posts : 361
    Post by Xelmon Mon Apr 07, 2014 6:44 pm
    I picked mine up from KMJ Performance a while ago and the GMC has been running really well with it.
    Post by panelmanrd Tue Apr 08, 2014 11:06 am
    I used the same plug just open the gap to .045
    diamond dave
    diamond dave
    Post by diamond dave Sat Apr 19, 2014 9:45 pm
    panelmanrd wrote:I used the same plug just open the gap to .045
    thanks. I think I will order one, and just swap it out before the nats this year.
    shorty
    shorty
    Number of posts : 135
    Registration date : 2014-01-01
    Post by shorty Sun Apr 20, 2014 6:18 am
    I purchased one for the 64. I bought a used one from a nova for the old 66 GMC. I believe this one is cheaper. Don't forget to buy new plug wires, as the old points style wires will not work.
    shorty
    shorty
    Post by shorty Sun May 04, 2014 5:42 am
    I decided to return mine and buy a re-man of an OEM. I didn't realist that the dizzy was all Chinese parts, and couldn't be repaired local parts stores. I also read a post where the dizzy was broken down completely, it was amazing to see how cheaply these are thrown together. JM2C
      Current date/time is Thu Mar 28, 2024 6:13 am
