+41
Vanner63
AZ SuperVan
whalemstr
Hip E van
Glazz74
Nacho
Tice84
cole63
Hawgford
Abitibi
LoveCrimes
cali2chitown
Red Falcon
EcoPU
'fish
FIZGIG
Carl
mark-t
mothradeath
CraigK
Ddavllc
bubbafrye
45 posters
Brent's Van (uante)
- Post n°101
Re: Brent's Van (uante)
I'd eat off of that floor. Nice work Brent.
uante- Number of posts : 1466
- Post n°102
Finally done with the bottom of the van. Finished today and installed the shocks and started putting the engine components back in place.
Finished! Well...for the most part
Rear shocks were tuff to get in. A furniture clamp did the trick for compressing it.
Engine Clean enough for me
Not the greatest working locations, but luckily the "management" doesn't mind a little tinkering! Can't wait to get my own workshop again.
- Post n°103
Looks Great under there Brent! Anything that helps preserve these longer is well worth the effort!
Space Truckin- Number of posts : 1278
- Post n°104
Very nice work
Big W- Number of posts : 3282
- Post n°105
Looking very nice indeed. Keep up the "inspirational" great work. Keep those pics coming.
- Post n°106
EcoPU- Number of posts : 104
Registration date : 2013-08-28
- Post n°107
Those are nice shocks, part# ?
- Post n°108
Cool Pix!! my wife called me ="Dumbass" the other day!! I reminded her @ that time = u know sweetheart ? That makes you = MRS. Dumbass"!! She left without saying a word!! I always cook anyways!!
- Post n°109
uante wrote:These are at Rock Auto...looks like it mentions different ones for front and rear. Is that the way to go?
http://www.rockauto.com/catalog/moreinfo.php?pk=294396&cc=1334618
Rear
http://www.rockauto.com/catalog/moreinfo.php?pk=294398&cc=1334618
Front
These are the ones I got. The rear ones were a bit of a trick to install. I used a furniture clamp I had laying around to compress it that last bit. I haven't lowered the van down and driven on them yet, but I think it will be much improved over the worn out ones were on there.
Front ones were easier since they are vertical.
- Post n°110
Thats the ="Good Ones" I always run those ="load assist" shocks on the fronts of all my cars! I also use the air ride shocks on rears too .
- Post n°111
Not a bad price either!
- Post n°112
Thank you, yours look much beefier than the KYB's I bought.
http://www.amazon.com/gp/product/B000C40T2S/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
- Post n°113
- Post n°114
Man, am I jealous!!!! That turned out Vantastic!
- Post n°115
It's not perfect, but sure is a lot better than I could manage painting it myself. I got the step for the side doors done too. Those came out really good, but I forgot to get a picture of that assy.
'fish- Number of posts : 222
- Post n°116
That does look good!!
I think you had a hard time with the shock because you have the truck resting on the axels, if the suspension had been hanging it would have slipped right in.
That truck is so clean really looks professional, amazing job!
- Post n°117
Thanks Fish...
Actually I did reposition the jack stands to let the axle hang. It was just with the coil over spring, the shocks are fully extended and although I could compress and insert the bolt in the front because it was vertical, with the angle in the rear it just wasn't happening. Those shocks are just too stiff to compress laying on the ground pushing up with one hand at an angle and trying to insert a bolt with the other. Maybe I just need more gym time
- Post n°118
- Post n°119
You got a Fantastic Deal my friend!!! Just think how much time you would have spent on those and how great they turned out! You're van is gonna look Fantastic and Thanks for all the pics...it's inspirational to the rest of us.
FIZGIG- Number of posts : 334
- Post n°120
The powder coat looks great. You should have went white on the doghouse cover.
- Post n°121
Can't do white, I'm not painting it white. If I wanted it the same as exterior color I could have done Navajo Beige.
- Post n°122
That would be cool!!!
- Post n°123
Does anyone have/know of a template for the glove box hinge holes? I aligned mine today, but since there wasn't one before, there isn't any holes. I think I got it pretty close and with a little larger hole, there will be some adjustment room.
It's just a pain because the hinges are on the inside so transferring the markings is a trick...just wanted to check before I drill. The antenna template worked well, and I have the one for the radio too.
- Post n°124
- Post n°125
Looks like you got it dead center...Nice job Brent!!!
