How do you tell it's a 4-11, what other numbers are on it?donivan65 wrote:yep,,,,I need to start seeing stuff looking pretty,,,,,,,,I guess installing the oil pump strainer on the oil pump is a start,,,,,,I guess the bolts are in one of those boxes,,,,,,I am not liking this 12 bolt, 4:11 positraction,,,,,,says 12-6-89 on it,,,,,,,It aint a 65 Chevy Van rear end for sure,,,,,,
+57
SteelyVan
Bear
AzDon
mattimuss
whalemstr
LiveWire64
richie61
ditdater
Rick's 66 Chevy Van
Marcosis
Tice84
vern01
66_Barracuda
deepott71
kookykrispy
Vantastic
drc
kaz
64chevy
NipRing
scarlin
JAX
66mnecotruck
SDEconoTruck
61 posters
Dons day,,,,,,,
- Post n°451
Re: Dons day,,,,,,,
- Number of posts : 12218
- Post n°452
Re: Dons day,,,,,,,
if its a 12 bolt cover, its a 3:73 or 4:11 and there are numbers on the ring gear that tell you the teeth,,,,,11-37 is a 10 bolt 3:36 highway use rear end,,,,as I pack up my tools and head for Jackes,,,,,
- Post n°453
Re: Dons day,,,,,,,
- Post n°454
Re: Dons day,,,,,,,
- Post n°455
Re: Dons day,,,,,,,
- Post n°456
Re: Dons day,,,,,,,
Good old dependable Doni-mow on the job! Nice piece of work! I'm sure Suzy appreciates that...
- Post n°457
Re: Dons day,,,,,,,
- Post n°458
Re: Dons day,,,,,,,
Take a well-deserved break and go run under a sprinkler!!! We're supposed to hit 90 this weekend here this weekend. That's pretty high for this time of the year here.
- Post n°459
Re: Dons day,,,,,,,
JackeFriend- Number of posts : 939
- Post n°460
Re: Dons day,,,,,,,
Hey that looks very nice! Good job!!
savage- Number of posts : 2625
- Post n°461
Re: Dons day,,,,,,,
Moving right along, You'll have that van back together & running soon.
- Post n°462
Re: Dons day,,,,,,,
Good work Suzy! Hey, Don, what's that other motorcycle next to your Honda?
- Post n°463
Re: Dons day,,,,,,,
- Post n°464
Re: Dons day,,,,,,,
- Post n°465
Re: Dons day,,,,,,,
Man, that looks puurrrrdy!!!
- Post n°466
Re: Dons day,,,,,,,
- Post n°467
Re: Dons day,,,,,,,
- Post n°468
Re: Dons day,,,,,,,
- Post n°469
Re: Dons day,,,,,,,
- Post n°470
Re: Dons day,,,,,,,
Everything looks so good!! Wow that engine looks like you could eat off of it!!!
- Post n°471
Re: Dons day,,,,,,,
- Post n°472
Re: Dons day,,,,,,,
Hey Don, those parts from Suzy's Chevy van look mighty familiar! Sorry some of them got a little rusty sitting in my driveway--for a year! I'm so glad to see things getting cleaned up, a coat of paint, and coming together!
Suzy, you've got it made in the shade there at Donivan's! Things will get done twice as fast with you working alongside Don.
Really glad to see that 4:11 getting replaced with a more MPG-friendly 3:36 (unless you were planning on doing some drag racing!). I've got the one in the middle, the 3:73, but I've also got a tranny with overdrive. I might switch to a 3:36 someday.
Some of the parts on your van have my fingerprints on them. I got that "burger fan" for my van, but your van needed it sooner (I've since picked up another). Let me know what you think of it. (Is it quiet enough? Push enough air to clear out the heat and fumes when parked at In-And-Out?)
I helped do the swap to a 2nd Gen master cylinder, and bend the new brake lines. And that's got Don's 2nd Gen sway bar too, so you don't have to cut notches in the belly pan! You can see it in this photo, dropping down to clear the longer master cylinder:
And I helped make the new wire loom for the engine compartment. We cannibalized a loom from a 70s Chevy car to get the right terminals for the newer alternator and to eliminate the external voltage regulator. The best part was replacing the stock connector with the tiny pins with a big plug from a newer car where wires pass through the firewall. Very rugged, with the same full-size spade connectors used everywhere else on the van. All the wires are crimped and soldered to those terminals. You can see one end of it in this shot:
I've got a roll of that same insulation you put in the doghouse. Did you use 3M spray mount? It's not super thick. How do you think it will perform?
- Post n°473
Re: Dons day,,,,,,,
- Post n°474
Re: Dons day,,,,,,,
- Post n°475
Re: Dons day,,,,,,,
