Brake conversion kit for 1968 G20 Handi Bus
Post by Guest on Wed Nov 06, 2013 7:50 am
I am looking to buy a brake conversion kit for disc brakes on my 1968 Handi Bus G20 with 6 lug pattern. I not sure what application will fit the front strait axle setup? What kind of car setup will work on this van?? I get the run around when I ask if kit will fit my application?? I need help!
Thanks
Chuck
ndjarrett
Number of posts : 357
Re: Brake conversion kit for 1968 G20 Handi Bus
Post by ndjarrett on Wed Nov 06, 2013 8:37 am
See this thread on VCVC...
http://www.vcvc.org/showthread.php/20121-M1D-Disc-brakes-2013
...maybe it will help.
Number of posts : 1732
Post by m1dadio on Wed Nov 06, 2013 7:35 pm
Chuck i sent you an email
m1D
Post by Guest on Thu Nov 07, 2013 10:52 am
I have gotten G10 questions answered. Has anyone done a G20 with six lug conversion? If so what did you use? I just want to swap front to disc brakes.
Post by G-Man on Thu Nov 07, 2013 10:57 am
I have a G20 and they have bigger brakes than a G10, mine stops great. I don't have the anwser for you, but what you have if they are working right should be good
Post by Guest on Thu Nov 07, 2013 10:59 am
So you are running just drum brakes all the way around? Did you change the three piece setup and run just 1 master cylinder and booster?
Post by G-Man on Thu Nov 07, 2013 11:24 am
yes drums all around, mine is factory stock
tarafied1
Number of posts : 24
Registration date : 2015-06-28
Post by tarafied1 on Tue Jun 30, 2015 7:48 pm
I know this is an old thread but it is exactly what I am looking to find out. Doesn't look like it was answered.
I have a 67 G20 but needs brakes. Missing the front drums and other parts, the rear is already converted to 5 lug. I would like to convert to disc. I cannot find anybody that can confirm if the brackets made for a G10 will fit a G20 spindle. I know the bearings are different so a different rotor would be needed (probably).
Maybe getting some info on a G10 spindle will help figure this out.
I measured a few of these points on the G20. Maybe someone that has a G10 spindle laying around could check those for me?
"M"
outer
inner
tarafied1
Post by tarafied1 on Tue Jun 30, 2015 7:51 pm
the backing plate bolts center to center up & down are 3" and across are 3.5"
what are they on the G10 spindle?
This would be where the brackets bolt on I assume
Post by Twinpilot001 on Wed Jul 01, 2015 6:18 am
i willbet the axles & Spindles -front -are the same on the g10 & 20's just brakes larger & heavier duty!! Hubs also. Thinking the 5 lug disc setups will fit the g20!! cheers
tarafied1
Post by tarafied1 on Wed Jul 01, 2015 11:42 am
Twinpilot001 wrote:i willbet the axles & Spindles -front -are the same on the g10 & 20's just brakes larger & heavier duty!! Hubs also. Thinking the 5 lug disc setups will fit the g20!! cheers
Unfortunately the G10 uses the smaller A2 & A6 wheel bearings like the Nova, Chevelle, etc. and the G20 uses the larger wheel bearings A3 & A5 like the C10 Pickups. The car rotor used in the kits is an 11" diameter. I can't find a rotor that uses the bigger bearings and an 11" rotor.
I confirmed with M1D that the brackets will fit but there is no known rotor (yet)
    Current date/time is Thu Apr 26, 2018 3:42 pm
