van crazy 65 chevy
Number of posts : 533
Re: van crazy 65 chevy
Post by Van crazy on Sat Sep 14, 2013 5:13 pm
Dog house side repaired. For some reason there was a hole cut in the side of the dog house and then boxed in under the seat there was a make shift bracket off the motor out the hole in doghouse. Possible ac bracket who knows but I fixed it thanks to this awsome parts guy I found a couple months ago. He has helped me out Tremendously with lots of parts he has cut out for me from door header and roof section to the dog house side, solid floor sections. I got couple doors from him with pop out vent windows sweet!!!! that makes for six vent windows going in.. sway bar and bunch of other stuff so thanks Dex If your out there greatly appreciated!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Post by Van crazy on Sat Sep 14, 2013 5:18 pm
Rear of the dog house, floor rot repair
Post by Van crazy on Sat Sep 14, 2013 5:23 pm
Does anyone know what this slot in the floor is for. my battery box is behind pass seat on the floor and I now this would be the battery box access if it were in the floor. Anyone ?
Number of posts : 9732
Post by vanny on Sat Sep 14, 2013 5:28 pm
I believe that was for the slide out step. Like a pivot arm that would push the step out from underneath the van when someone opens the side door. I also believe there was a plastic cover over it. By the way, that's some fantastic progress in there. Looks really nice. Keep it up and keep the pics coming!!!!
Post by Van crazy on Sat Sep 14, 2013 5:47 pm
Thanks vanny I wont be putting any steps on in the near future.
Post by Van crazy on Sat Sep 14, 2013 6:08 pm
What year camaro bumpers fit my van if any?
Post by G-Man on Sat Sep 14, 2013 6:11 pm
jrinaman has them on his van, PM him
Post by Joe Van on Sun Sep 15, 2013 5:24 am
Your Van's progress is moving right along looks GREAT you should be on the road in no time cheers..metal work looks Awesome.!!!! I have a spot on the right front of my 2nd Gen dog house I have to deal with How did you get that L bracket or angle iron to bend around the back of the box with out it kinking.scratchand what gauge was it??? looks really good......... ...THANKS ...JOE...
Post by Van crazy on Sun Sep 15, 2013 6:01 pm
JOE VAN wrote:Your Van's progress is moving right along looks GREAT you should be on the road in no time cheers..metal work looks Awesome.!!!! I have a spot on the right front of my 2nd Gen dog house I have to deal with How did you get that L bracket or angle iron to bend around the back of the box with out it kinking.scratchand what gauge was it??? looks really good......... ...THANKS ...JOE...
I bought a shinker strecher you pick them up for 150 bucks or so it works great must have for radius. Its 20 ga shrinker strecher good up 18 ga at least the one I have I got it at harbor frieght. the floor is 16 ga and I had to hammer form the beads in the floor.
Chevy bowtie cup holder
Post by Van crazy on Mon Sep 23, 2013 3:08 am
I dreamed this up the other day and made it reality this weekend.
Post by Van crazy on Mon Sep 23, 2013 3:12 am
This is my first vinyl skin. I made 2 the first was'nt the greatest 2nd much better. I needed a test piece anyway.. I still need to make the mount off the front of the doghouse.
Number of posts : 3754
Post by Digz on Mon Sep 23, 2013 3:15 am
Looks like it was a cool fun project !
Post by millwright71 on Mon Sep 23, 2013 4:02 am
Looks really good! A fun project for sure.
Post by G-Man on Mon Sep 23, 2013 6:02 am
Love to see some of the very cool,ideas you guy come up with
Post by vanny on Mon Sep 23, 2013 7:53 am
That's gonna look awesome once installed! Nice piece of work!
Post by Van crazy on Mon Sep 23, 2013 1:29 pm
Thank guys it was fun to change it up a bit.
Number of posts : 820
Post by mbasaraba on Wed Oct 02, 2013 7:33 am
Like others have said I am interested in the window frames for the back windows. Mine were pretty rough. I sanded and pour15 them hoping to at least make due but they really dont look good. I was thinking of just getting glass put in the openings instead but really dont want to if I could find a way to make/buy the frames.
Looks like a major project you took head on! Really good thread man.
Post by Van crazy on Wed Oct 02, 2013 1:56 pm
Matt will get back to you on the frames I have to master that. I need to make a better fixture and then I should be able to make perfect every time. Ya when I first bought it my initial plan was to drive first but there was just to much that needed to be done.
Number of posts : 2041
Post by dodge man on Wed Oct 02, 2013 7:19 pm
awsome job, love to see a pro do his thing on body work, cant wait to see her in color,
Post by Van crazy on Sat Mar 22, 2014 3:51 pm
Well work has started again. I picked this fuel tank up from Brothers it comes with 30 ohm sender and straps. Item GTPDS66 on sale 189.99 it fits in between crossmembers and straps need to be reconfigured. I tweeked the neck on tank down and forward slightly to get it in line with the fill neck because fill is not in center like original. The fill is 1 3/8 and the vent is 1/2 same as the stock fill tube I picked up the fill hose at fillernecksupply.com there is a couple vent tubes not being used that will need to be pluged
Post by Joe Van on Sat Mar 22, 2014 4:29 pm
Look's Great Van crazy....Just to make sure I am reading this write the tank fit between the cross member's with out any modification besides the straps??? and the reason you moved it all the way to the right is because of the filler neck..Correct..if so then I myself would just have to move the filler neck forward a little to put the tank back in the stock location where the 16 gallon was/is ...How many gallon tank is it??...I am just trying to figure out what will fit my 1ST Gen without drilling out the cross-member to relocate it. For me moving the filler neck is no problem...Thank's ..Joe....
Post by Van crazy on Sat Mar 22, 2014 4:53 pm
Joe this is the tank for you the only mod I had to do to the was cut a little bit of the cradle bracket on front crossmember here is a pic on that and thats it plug the extra vents and you are good to go. And straps I was out earlier and I was able to shift it almost to center with no problems. You could probably do it without mod. but it will be 2" lower right now it tight to the floor witch I plan on putting 1/4 rubber between tank and floor to isolate it.Joe there was no need to move the neck I just put pipe in filler tube pried down and forward while taping on tank just under filler neck to help everything move easier thats it no fab at all.
Last edited by Van crazy on Sat Mar 22, 2014 4:58 pm; edited 1 time in total (Reason for editing : adding)
Post by Van crazy on Sat Mar 22, 2014 5:07 pm
Here is the air cleaner setup im working on I picked up an oil bath air cleaner from 50-60 chevy and a air cleaner off a 70 pickup and combined the two to make some what factory air cleaner.
vrod64
Number of posts : 67
Registration date : 2013-07-20
Post by vrod64 on Sun Mar 23, 2014 3:06 pm
Very insperational !
Love the Passion.
V
Post by millwright71 on Sun Mar 23, 2014 7:58 pm
Looking really good! I like the fab work most of all.
    Current date/time is Tue May 22, 2018 4:31 pm
