+10
Rick's 66 Chevy Van
14 posters
van crazy 65 chevy
Van crazy- Number of posts : 533
- Post n°26
Re: van crazy 65 chevy
I built a booth the last couple days I started a little fiberglass and soon relized paint wasnt happening with out it. Now I can control the dust and over spray through the whole process. It works great and im hoping for a professional finish. Im running 2 turbine 8" fans for the exaust they really move some air I plan on cutting 2x2 filter holes for venting front to rear.
- Post n°27
- Post n°28
Me to im so excited to get some primer on it been a long time striping down I can't wait.
- Post n°29
In primer finally
- Post n°30
- Post n°31
- Post n°32
- Post n°33
Looking Great VC! Are those spaces in the drip rail to allow the water to drain so that it doesn't build up and eventually rust? That's looking nice and smooth! Nice piece of work!
- Post n°34
- Post n°35
- Post n°36
- Post n°37
- Post n°38
No I have to install the connector strip still little piece about one inch wide bent over and under I didnt want to leave the factory piece on there this way it wont bleed rust in the future.vanny wrote:Looking Great VC! Are those spaces in the drip rail to allow the water to drain so that it doesn't build up and eventually rust? That's looking nice and smooth! Nice piece of work!
- Post n°39
- Post n°40
- Post n°41
That's a major amount of effort and your making it look good !! I hear you on the drip clip, I have a tiny streak of weirdness under one, either from rust or paint stripper residue.
- Post n°42
Lots of sanding every thing was done by hand I really hope for a "SHOW SHINE" this is my first. At this point I hear its all about what kind of gun I shoot it with the paints got to go on right or everything I have done will be lost in the sauce.vanny wrote:Looking Great VC! Are those spaces in the drip rail to allow the water to drain so that it doesn't build up and eventually rust? That's looking nice and smooth! Nice piece of work!
- Post n°43
ya I have about 12 hours in fab work in that pass door is it worth it im not sure I didnt have another door to use and then I saw one up for sale the other day in the g parts section oh well.Digz wrote:That's a major amount of effort and your making it look good !! I hear you on the drip clip, I have a tiny streak of weirdness under one, either from rust or paint stripper residue.
- Post n°44
Is there rubber grommets for hinges on the front door skins and body? Or are they on the cargo doors only the cut is a bit different from side doors.
savage- Number of posts : 2625
- Post n°45
Most of the vans I seen don't have hinge gaskets on the front doors(holes are bigger then S&B doors) They used sealer on them from Factory. Front door(& everthing else) looks Great ,Ton of work as you said. You ever find the Sportvan emblems you were looking for??
- Post n°46
No I never found the emblems you got some? just another missing link!savage wrote:Most of the vans I seen don't have hinge gaskets on the front doors(holes are bigger then S&B doors) They used sealer on them from Factory. Front door(& everthing else) looks Great ,Ton of work as you said. You ever find the Sportvan emblems you were looking for??
- Post n°47
Yes, Let me check to make sure there good enough for your Major rebuild project
- Post n°48
Dude this is awlsome work thank you for sharing!!!!
- Post n°49
Looks very familiar for sure VC. You and I are running almost dead even on our projects. Looking good!
- Post n°50
