    Engine Cradle Torque
    Number of posts : 1651
    Engine Cradle Torque Empty Engine Cradle Torque
    Post by Scott Sun Jun 30, 2013 9:54 am
    I just finished putting the oil pan back on and bolted up the engine cradle, but all my books are in storage until I move.
    Can any of you give me the Torque I need for bolting the engine cradle back to the frame?
    And the Torque I need for the bolt that goes through the rubber pad.
    Number of posts : 2626
    Engine Cradle Torque Empty Re: Engine Cradle Torque
    Post by savage Sun Jun 30, 2013 5:37 pm
    I'll give you what I found in the "Chey Van Shop Manual Supplement"
    {engine mounting torque specifications}
    engin front mount   7/16-14   50-70 ft #
    engine front mount atching   3/8-16   20-30 ft #
    front mount bracket  3/8-16 20-30 ft #
    crossmember bracket(if used)  38-24 20-30 ft #
    crossmember (to frame) 1/2-13 100-130 ft #
    engine rear(trans) support   7/16-14 55-75 ft #
    Hope it helps,& is what your looking for
    Post by Scott Sun Jul 01, 2018 5:09 pm
    Thanks Savage, it was helpful then, and it was again today.
      Current date/time is Fri Apr 19, 2024 11:10 am
