    pop out window rubber
    BoneMan
    BoneMan
    Number of posts : 169
    Registration date : 2011-06-23
    pop out window rubber  Empty Re: pop out window rubber
    Post by BoneMan Mon Apr 07, 2014 3:38 pm
    Success!  A perfect fit.  $7 each at Pick-n-Pull.
    Donor - 1995 Dodge full size Van with factory tinted pop-out windows.
    These two weatherstrip pieces fit my A108 flip-out windows perfect.  Corners matched, and the total length was spot on! Zero cutting.
    (i assume link will be dead once they crush it)
    http://row52.com/Vehicle/Index/2B6HB21Y3SK555009
    I'm going back for the latches to see if I can get them onto the A.  Need a punch to push out the roll-pins.   (latches are black with 3 screws holding them to the door frame - just like an A!)
    Also next trip, I'm going to measure the exact glass size on the 1995 - seems almost identical based on the weatherstrip.  The factory tint glass is awesome.  It's that factory tinted glass with the black metal edge all around.
    Getting hot out here in Cali!
    Number of posts : 8726
    Post by dix Fri Oct 25, 2013 1:40 pm
    If it does not have to be new then go to a junk yard and take the seals from a dodge mini van the windows behind the sliding side doors have the same rubber gasket, and a lot less money.
    Post by Guest Thu Oct 24, 2013 8:31 pm
    Any guidance as to which ones?
    pop out window rubber  Empty pop out window rubber
    Post by dix Wed Apr 10, 2013 2:03 pm
      Current date/time is Fri Mar 29, 2024 1:57 am
