rebar
supernaut
    Cragar Wheels For My '68 A100
    Cragar Wheels For My '68 A100 Empty Cragar Wheels For My '68 A100
    Post by Guest Tue Feb 05, 2013 5:08 pm
    I recently rescued a '68 A100 Window Van. It desperately needs new wheels and tires as what it has now are all mismatched and the tires are rotted. Perhaps this is common knowledge on here, and I did use the search function, but I'm just at a loss as to what size / type wheels I need.
    I would like to buy some Cragar wheels, ideally with the 61614's up front and the 61616's in the rear. Looking around in various posts and forums it seems that these will fit, but before dropping all that cash I want to be 100% sure.
    Cragar 61614
    08/61 Series Super Sport Wheel
    Size: 14'' x 6''
    Bolt Circle: 5 x 4-1/2", 4-3/4", 5"
    Rear Spacing: 3-3/8''
    Offset: -3mm
    Cragar 61616
    Size: 14'' x 6''
    Rear Spacing: 2''
    Reversed Offset: -38mm
    I'm pulling the information and pricing from here:
    http://www.jegs.com/p/Cragar/Cragar-08-61-Series-S-S-Super-Sport-Wheels/755662/10002/-1
    Any help on this would be great. Do I need anything else like lug nuts, etc?
    Sorry for the noob post.
    -SIN
    supernaut
    supernaut
    Number of posts : 73
    Registration date : 2012-10-15
    Cragar Wheels For My '68 A100 Empty Re: Cragar Wheels For My '68 A100
    Post by supernaut Tue Feb 05, 2013 5:31 pm
    i've been seeing a white one on the southside recently. is that you?
    Number of posts : 3046
    Post by RodStRace Tue Feb 05, 2013 5:53 pm
    The front should fit no problem. The rears should too, it's only an inch out from neutral (4" instead of 3").
    Provided you have a fairly normal tire on that 6 inch rim.
    there are many vans with 8 inch rims which also have 4" out from the hub with neutral offset.
    Post by Guest Tue Feb 05, 2013 6:09 pm
    RodStRace wrote:The front should fit no problem. The rears should too, it's only an inch out from neutral (4" instead of 3").
    Well I'm going to have to get new tires too so I guess I need to figure out what fits these wheels.
    Post by Guest Tue Feb 05, 2013 6:11 pm
    supernaut wrote:i've been seeing a white one on the southside recently. is that you?
    No, I live NW Austin. It's been at Atomic Garage in Round Rock for a week and I finally get it back tomorrow. This is me (prior to their body work):
    http://sintax.low12.com/tagged/van
    Is there any kind of van scene here in ATX? I'm in an MC and that is pretty much my life so anything in the CC world is foreign to me at this point (outside of Lonestar Round Up)
    supernaut
    supernaut
    Post by supernaut Tue Feb 05, 2013 6:51 pm
    just thought i'd ask. i've been seeing a really clean off white a100 parked off the freeway this past week. i know there's one or two other dudes with vans here in austin, but i haven't met them. my van is up at murpho's right now getting some engine stuff done as well. it should be out this weekend or next week and ready to shred around town. nice looking van. i'm down to start up a VC once i meet a few more people
    rebar
    rebar
    Number of posts : 151
    Post by rebar Tue Feb 05, 2013 9:28 pm
    Got a '67. Ran some old mags for 30 years that fit well – 15 x 6.75, 5 x 4.5 bolt circle, with 3-3/8 rear spacing (to outside of the lip), and 4-3/8 front spacing (outside of lip). Now running 15 x 7 with 4.25 rear spacing and 3.75 front spacing. Soon to change to 15 x 7 with 4" rear/front spacing. I wrote a note to myself way back saying that the rear spacing should be no greater than 4.5", but that might not apply to low profile tires.
    Use to have wider tires in the rear but can't remember what that size was – I'm sure someone else here can help with the max size.
    I run the same size all around now and the largest I'm comfortable with that lets me keep the tightest steering radius is 215/75 15. Tire shop did their usual huckster thing once and talked me into wider, spendier ones but they rubbed up front – so they ended up doing twice the labor by changing them out for the ones I originally asked for. Pity.
    I know some folks here run wider tires and at least one member has 235/70(?) 15s, but I don't know what their back and front spacing is.
    Post by Guest Wed Feb 06, 2013 12:22 am
    rebar wrote:Got a '67. Ran some old mags for 30 years that fit well – 15 x 6.75, 5 x 4.5 bolt circle, with 3-3/8 rear spacing (to outside of the lip), and 4-3/8 front spacing (outside of lip). Now running 15 x 7 with 4.25 rear spacing and 3.75 front spacing. Soon to change to 15 x 7 with 4" rear/front spacing. I wrote a note to myself way back saying that the rear spacing should be no greater than 4.5", but that might not apply to low profile tires.
    It seems most people are running 15's over 14's. Perhaps I should go with these then:
    Size: 15'' x 7''
    Bolt Circle: 5 x 4-1/2" 4-3/4", 5"
    Rear Spacing: 4-1/8''
    Offset: 3mm
    Size: 15'' x 7''
    Rear Spacing: 2-1/4''
    Reversed Offset: -44mm
    Number of posts : 714
    Post by Gothboy Wed Feb 06, 2013 4:36 am
    Im not surew what my spacing is, but Im running 235/75 r15's on stock dodge a108 rims. The front rub on turns, but i have no other issues. Just an fyi for size. Smile
    rebar
    rebar
    Post by rebar Wed Feb 06, 2013 8:36 am
    Thank you Mr Gothboy. My original a108 rims are 15 x 5.5 with 4-3/32" rear spacing.
    rebar
    rebar
    Post by rebar Wed Feb 06, 2013 8:46 am
    [quote="sintax"]
    rebar wrote:Perhaps I should go with these then:
    Size: 15'' x 7''
    I might be concerned about the shallow rear spacing, leaving too much front spacing which might cause the front to rub on turns like Gothboy noted. His 235/75s rub so maybe the shallow rear spacing will cause even 215/75s to rub.
    Number of posts : 956
    Post by slowflapper Wed Feb 06, 2013 8:48 am
    I run 14's and would recommend that you run 15's instead. 14" tires are getting hard to find (read: more expensive) and 225/70/14 Coopers are about the biggest white letter you can get unless you start buying Mickey Thompson Indy Profiles which are really expensive.
    15" rims will give you a much better option on rubber and probably fewer rpms going down the road than 14's as well. On a side note, check Summit racing for rims too, they have pretty good pricing and do carry thier own "summit" brand which looks pretty good.
    Post by Digz Wed Feb 06, 2013 8:55 am
    I have a pair of 15x7 keystones with the 2" backspacing. You wouldn't want them on the front for the rubbing on turns reason. They would give you that wide look on the back tho.
    rebar
    rebar
    Post by rebar Wed Feb 06, 2013 10:02 am
    rebar wrote:Thank you Mr Gothboy. My original a108 rims are 15 x 5.5 with 4-3/32" rear spacing.
    NOTE: I also picked up a couple 15 x 5.5 rims from the boneyard that were from that era that have a 3-3/4" back spacing.
    Post by Guest Wed Feb 06, 2013 7:31 pm
    ive got 15x10s on the back and 15x8 up front just flipped the rear shackles
    rebar
    rebar
    Post by rebar Sun Feb 10, 2013 11:49 pm
    jonnyrose wrote:ive got 15x10s on the back and 15x8 up front
    What size tires are you running?
    lws67
    lws67
    Number of posts : 193
    Post by lws67 Sun Mar 03, 2013 7:00 pm
    I've got 215/65-15 Cooper Cobra's on 15x6 Keystones up front and 255/60-15 on 15x8 on the rear of my 67 panel, no chassis mods. It has a nice stance with no rubbing at all. I might go with a slightly taller tire on the front next go round, not sure Smile
      Current date/time is Fri Mar 29, 2024 1:05 am
