dulcimerbob
    Brakes question
    Number of posts : 2086
    Brakes question Empty Re: Brakes question
    Post by Seth G Mon Dec 11, 2017 6:47 pm
    Did you have the drum turned? Maybe they reglazed the shoes b/c of 10 years of oxides ect?
    This is one of those weird backwards threads, why does this happen?
    gabeveliz
    gabeveliz
    Number of posts : 4
    Registration date : 2017-11-16
    Post by gabeveliz Mon Dec 11, 2017 4:03 pm
    R&R?
    AthensTxMc
    AthensTxMc
    Number of posts : 61
    Post by AthensTxMc Sat Nov 11, 2017 9:11 pm
    One major upgrade on the drum brakes if it doesn't have it and very cost effective .. Self adjusters .. They will stop that pull to the side most of the time under braking ..
    Post by Big W Thu Jul 31, 2014 9:50 pm
    Good plan. I went all new on 4 corners with hers van. $400.00 +...best money I ever spent for safety.
    dulcimerbob
    dulcimerbob
    Number of posts : 115
    Post by dulcimerbob Thu Jul 31, 2014 3:35 pm
    Thanks for the replies . I am going to r/r wheel cylinders and shoes tomorrow. Master cylinder on order. Rather have new than rebuilding the old. Cool
    Post by Twinpilot001 Thu Jul 31, 2014 2:55 pm
    r & R master cyl!!
    Post by Big W Thu Jul 31, 2014 2:32 pm
    Could you have a seized wheel cyl. Maybe one side of a cylinder is working but not the other? Just went through that with the wifeys van and her peddle was good to, but crappy for stopping. Found driver side cyl was stuck solid on front shoe, and passenger side was leaking, which explains the low brake fluid...lol.
    dulcimerbob
    dulcimerbob
    Brakes question Empty Brakes question
    Post by dulcimerbob Thu Jul 31, 2014 7:24 am
    My brake pedal is hard and has low power. L have sanded the shoes, cleaned all the hardware, flushed and bled the lines and adjusted the brakes. Still not as good as I have had in the past wirh other E's brakes. The PO did a brake job on it and parked it for 10 years . I suspect the old shoes that look good. Any help appreciated.
      Current date/time is Thu Mar 28, 2024 6:03 am
