well, I traced the supports (frame rails) on the underside of the floor patch panel..drilled several holes with a weld cutter so I could weld her down solid to the supports.Worked great.Welded her in using caution near the wire harness. Oh yea, I covered the wires underneath the floor with a plastic piece of loom........
+16
Murdock
66ThunderVan
2345.coupe
20 posters
my falcon econoline van
2345.coupe- Number of posts : 92
Registration date : 2012-12-11
- Post n°76
Re: my falcon econoline van
thanks Murdock,vanny, and Big W..........
- Post n°77
LOOKS SUPER
- Post n°78
No more Fred Flintstone stops!!! Great Job Coupe
Good idea covering up those wires too.
wylee- Number of posts : 917
- Post n°79
great.. keep the pic comin...
Murdock- Number of posts : 313
- Post n°80
Looks good, I like the bottom solution as it seems easier than the "X". Is it critical to put drain holes in?
- Number of posts : 8726
- Post n°81
and so what's next
- Post n°82
I always assumed the X was for extra rigidity.
- Post n°83
what's next........I hate to say it, but it's the interior....the surface rust has to be dealt with.dix wrote:and so what's next
I also need some feedback on ,should I keep the roof vent or weld in a piece of metal to seal up the hole.....
[img:16a5]http://ig/IMG]
- Post n°84
does the roof vevt work and does it leak?? If it is not cracked and works well then i'd remove it and reinstall it using modern day sealents but not laytex. use the interrior links to get some ideas floting around in the head. If you already chose a exterior color then paint the door jams and the inside of the doors and the floor at the door openings . this way what ever you install it's finished already. you dont want to paint next to any thing finished. your project is comming along nicely . you also should paint something over any interior rust before it's covered..
- Post n°85
these vans get hot in the summer, i would keep the vent, like dix said as long as it works and no leaks,,
- Post n°86
well got her all stripped down and ready to wire brush her......
got some floor issues to take care of first.....
man photobucket has been a real pain in the *ss to use since the big"change"...more later
- Post n°87
floor issues concerning the accelerator pedal
still have to weld her in.......
Dodger 359- Number of posts : 94
- Post n°88
Awesome welding! Keep the photos coming on your project.
- Post n°89
Way to keep picking away at it Coupe! Making progress is always a good thing. And as always, Thanks for the pics
- Post n°90
it's all lookin' good !!
- Post n°91
- Post n°92
- Post n°93
- Post n°94
BEFORE YOU KNOW IT, IT WILL BE READY FOR PAINT, NICE JOB,,
- Post n°95
I swear I just heard the van say "It's about time someone gave me some attention!" Coupe your doing a fantastic job of bringing this one back to her former glory. Keep up the great work and as always, Thanks for providing pics. They're inspirational
- Post n°96
haha dodge man there's a lot more work to go before paint...dodge man wrote:BEFORE YOU KNOW IT, IT WILL BE READY FOR PAINT, NICE JOB,,
hey vanny, you've got great hearing......
it's going slow ,but it's going.....got the drivers door done, found another hole to repair. Next the dash, roof and side walls...
[URL=http:
[URL=http:/
[URL=http://
- Post n°97
it makes a big difference when you have the wright tools, and of corse know what your doing, it looks like you have both,,,
- Post n°98
- Post n°99
looks like a nice old ford pick up in the garage too, what is it?
- Post n°100
'48 f-1,50 cab,fresh '68 mustang 351w,'75 LTD c-4,'57 f-100 9"rear,modified the rear frame rails so I could put the rear end on top of the leaf springs.Rear fenders are 8" off the ground.Painted it with the original color, meadow green,grille is Tucson tan and cleared it with the Eastwood flat no shine clear coat.
If you want,pm me your email and I'll shoot some pics.
