+16
Murdock
66ThunderVan
2345.coupe
20 posters
my falcon econoline van
wylee- Number of posts : 917
- Post n°101
Re: my falcon econoline van
lookin good, its a pain taking so long on some things. but when ya finish and step back its a great feeling. keep the pics comming.
2345.coupe- Number of posts : 92
Registration date : 2012-12-11
- Post n°102
yea wylee it's painstaking, but it's coming.....lot of hand sanding with 220 grit and then cleaned her up with adhesive cleaner. The sanding phase on the dash is pretty close to being done.wylee wrote: looking good, its a pain taking so long on some things. but when ya finish and step back its a great feeling. keep the pics coming.
- Post n°103
what color are you going use?
- Post n°104
well dodge man, I was thinking of doing the original color.I'll have to get the color code off the tag on the drivers door, look it up on the web and get back to you. My guess it's a cream or light yellow.......dodge man wrote:what color are you going use?
- Post n°105
code #8....Springtime Yellow....!2345.coupe wrote:well dodge man, I was thinking of doing the original color.I'll have to get the color code off the tag on the drivers door, look it up on the web and get back to you. My guess it's a cream or light yellow.......dodge man wrote:what color are you going use?
- Post n°106
cant wait to see it in paint, its going to look good,,
- Post n°107
- Post n°108
it will come out better when you take your time, lookin good,,
- Post n°109
- Post n°110
Coupe, your getting there man. Just think, once your all done, you've got all these pics to remind you of all the hard work you put into it. I can't believe how far you've gotten on this project. Just keep the faith and you'll get there. YOU CAN DO IT!!! Please continue sending pics as well so we can be right there with you!
Thanks - Vanny
Thanks - Vanny
- Number of posts : 8728
- Post n°111
coupe what are you using on the inside wall to remove the paint??
- Post n°112
- Post n°113
- Post n°114
Every time I get on the snap on truck I always ask if the price includes a pair of lips! Buythe best, cry once! With that said, project looks good!!
- Post n°115
campin'fool 2- Number of posts : 252
Registration date : 2013-02-02
- Post n°116
Looking good. Hows the entertainment value of that job holding out?
Joel
Joel
- Post n°117
At least he has a chair to sit on. Otherwise, the knees would take a beating!
- Post n°118
just do a little every day and it will get done before you know it,
- Post n°119
Coupe,if you get tired of the Crud Thug, maybe you could try this? www.youtube.com/watch?v=__qOY9hcm64
- Post n°120
Hey vanny...thanks, I do have it pretty good.....also the rug you see in the last pictures is for my old knees
camping'fool 2....no entertainment now,it comes later when I start spraying.....
dix...your so right, little by little it will get done
- Post n°121
floor all wire brushed.....found two issues....the gas pedal issue is the worst. The rod attached to the gas pedal under the rotten floor rotates.I'll have to think about this for a bit.I'd like to shove a piece of thick copper under the rotten floor board between the floor and rod and then weld the rot on low amps. I'll sleep on it.
I also got 25% of the ceiling done......can't wait to finish this part up......
- Post n°122
Sometimes it's best to take a break, walk away and think it through. Man, you really made some major progress quickly. It won't be long now. Great work, Coupe! Once again, thanks for the pics.
- Post n°123
not much rust left, it looks real good,
- Post n°124
- Post n°125
Making great strides there, Coupe! Almost there!
