Operation BREADBOX
mothradeath
Number of posts : 215
Re: Operation BREADBOX
Post by mothradeath on Thu May 05, 2016 5:31 pm
Keep crackin away! Just got mine mobile and to the glass shop for a windshield!
Number of posts : 1810
Post by Seth G on Thu May 05, 2016 9:24 pm
AWESOME!!!!!!!! Twisted Evil
All the work is amazing, subtle and not so subtle. It all over the map and I'm drooling over it Smile
theogbigd
Number of posts : 73
Registration date : 2015-11-10
Post by theogbigd on Fri May 06, 2016 12:10 am
I'm looking to do the same, but It doesn't need to be laying frame. With that being said, do I need to switch out the chassis etc just to lower it? Or can I put bags on it and see how low it gets?
Number of posts : 169
Post by wirepuller on Fri May 06, 2016 9:59 am
Thanks guys!
Mothradeath, it looks absolutely killer!!
theogbigd, you can do a C-Notch and 4link setup for the rear. A couple of guys here have done it very successfully, and is somewhat easy to do, if you have some fabrication skills.
Up front is more complicated with air bags. Choices are an IFS swap (Click here), mono leaf spring with air bag assist, or some funky hybrid 4 link / tuning fork setup which is extremely complicated and not recommended.
Projects worth looking at:
Heinz57 Project
66e100pu Project
Homebrew Project
Suicide King Project
Mothradeath is doing a wicked slammed E100 too, but I can't seem to find his post.
Have some reads, do some planning and feel free to bounce ideas off the guys here, there are some great resources available!
WP
theogbigd
Post by theogbigd on Fri May 06, 2016 10:26 am
Appreciate the advice! Where would you buy an ifs setup?
Post by wirepuller on Fri May 06, 2016 12:14 pm
I bought the Universal kit from Full Tilt IFS.  They provide a high quality product for a real good price.  I did lots of shopping around and spoke to the guys directly.  They would be my recommendation.
WP
theogbigd
Post by theogbigd on Fri May 06, 2016 4:36 pm
Thank you!
Post by wirepuller on Mon Jun 06, 2016 11:04 am
I fabricated a bracket for the steering column heim joint.  It hides nicely under the existing column support.  I'll post a pic of it once I have it off and fully tacked down.
Next I had to figure where a good location for the steering box would be.  Right about here looks good.
Then I tacked the steering shafts to the UJoints and bolted it together.  Yup, I'm Canadian...that's black hockey stick tape holding it all together!
Here you can kind of see the hidden heim joint
And roughly in place, minus the steering box support brackets.  It will move up above the lowest level of the body and towards the front cowl.
Next I had to fabricate a filler panel where the existing steering equipment was located.
And here it is all tacked into place.
I need to finish weld the filler panel, fabricate a bracket to hold the lower heim joint for the R&P shaft and design secure mounting brackets for the steering box.  Also need to source out a vendor that splines steel shafts so I can mount my steering wheel to the steering shaft.
I sourced out some rigid type L 1/2" copper tubing for my air lines.  I have a line on a stainless steel tubing bender, so my bends should be tight.  I am undecided if I want to bury them below the floorboards, or run them along the sidewall ribs of the van to show them off.  If I go exposed, I plan to patina the fittings and fasteners and polish up the tubing.  Below is the exposed plan.  Keep in mind the back will have floorboards right across where the IRS is, so I can run the passenger side air line under the rear seats, if I put some  in.  Up front, I'll run it behind the front wheel tubs and maybe fasten to the doghouse for the passenger side...Not sure yet.
WP
Post by Big W on Wed Jun 08, 2016 7:00 am
Looking real nice wirepuller. Awesome build cheers
Number of posts : 9097
Post by vanny on Wed Jun 08, 2016 10:54 am
Some very Talented builders on this site!!! Twisted Evil cheers
Post by wirepuller on Tue Jun 28, 2016 8:47 am
My idea for a WWII Bomb gas tank has taken one step closer to realization.  I've seen a few rat rods with them, and since I changed the name of my van to YEG'R Bomb, I thought it would be fitting to have a bomb gas tank.  Something like this:
Here is my design
With ALOT of hesitation, I decided it was time to cut open the propane tank.  Since I didn't have a wrap around tool, I had to create my own.  Enter Christmas wrapping paper, it's thin, straight edged, and kind of waxy, so it can be painted without going all soft and mushy.  I wrapped a piece around the tank, lined up the edges and taped it off.  Next I applied some yellow marking paint to create my nice straight line.  Note that I wrapped the paper so the overspray would be on the piece I am cutting out, so the tank retains it's old, crusty and rusty appearance.
Then it was do or die time, instead of cutting it with the zip disc, I took a safer approach and used a sawzall.  Overall, I cut 10" out of it so it will hold roughly 80l of fuel.
Ready to be welded back together, once I fabricate some baffles.
Oh, and apparently kids dab these days, so my kids insisted I post a picture of me dabbing in front on the van, to which they had a good laugh.
WP
Dantra
Number of posts : 281
Post by Dantra on Tue Jun 28, 2016 9:27 am
Amazing project
But I'm clueless as to what a "dab" is lol
Post by wirepuller on Tue Jun 28, 2016 12:47 pm
It's a dance move like the nay-nay, the whip, the bop, the macarena.....basically line dancing for the younger generation.
WP
Post by vanny on Tue Jun 28, 2016 5:19 pm
wirepuller wrote:My idea for a WWII Bomb gas tank has taken one step closer to realization.  I've seen a few rat rods with them, and since I changed the name of my van to YEG'R Bomb, I thought it would be fitting to have a bomb gas tank.  Something like this:
Here is my design
WP
My Grandson was doing that in the living room tonight and I said what the heck was that? He responded, " That's dabbing!" Too funny....
Where is that tank going to get mounted on the van?
Number of posts : 294
Post by jrdunn96 on Tue Jun 28, 2016 5:20 pm
I was "blissfully ignorant" myself.
Post by wirepuller on Wed Jun 29, 2016 9:49 am
Picked up some sheet steel for the tank baffles.  I placed one sheet under the cut out portion of the tank and scribed the corners so it would fit.
And then I cut two pieces.  Sorry for the blurry pic.  These will be the vertical pieces to slow the sloshing from side to side.
Then I measured for the horizontal piece to go between the two vertical pieces, cut, test fit and welded them together.  These will slow the sloshing from front to back.
then I put the piece into the one half of the tank
and thought...gee, the vertical piece isn't doing much good at the end of the tank, so I decided to invert my design and press on. In order to secure the two pieces together, I drilled a small hole in the center of the flat piece and tack welded the two pieces together so they don't rattle.
From here I had to massage, grind and bang it into alignment so the tank would go back together.  Pretty much as I was crossing the finish line welding the tank together, I ran out of welding gas, so I put it in the van to see how it would look.  It may shimmy left or right so it looks centered, and I have to finish with the bomb "fins" on the end of the tank.  I also cut the foot off the bottom of the tank so it is more rounded and I need to remove that guard looking thingy where the valve usually is on those tanks.
WP
Post by wirepuller on Thu Aug 11, 2016 10:53 am
Not too much progress on the project lately, as another project took over my life for the last 6 weeks.  We decided to gut/reno the kitchen and I'm just about done.
Before:
After:
But I did manage to squeeze in some garage time this week and finished up the steering.  The steering wheel is from a 60s Fiat, couldn't tell you what model, sorry, it was wiggle room only under the van, so pics aren't the greatest.
WP
Post by vanny on Thu Aug 11, 2016 6:35 pm
Gotta squeeze those home projects in for a "Happy Life"... HGTV has nothing on you, nice work! Steering looks great too! Wink
Post by wirepuller on Fri Aug 12, 2016 8:07 am
happy wife, happy life!!!
Thanks Vanny!
WP
Poochie
Number of posts : 45
Registration date : 2013-01-13
Post by Poochie on Sat Oct 22, 2016 5:58 am
Mind officially blown. This is amazing. I've been researching how to drop my Econoline for years and just read through your thread.
My own goals are a bit more modest than yours. As I read through your thread and realize how much work lies ahead of me, I'm going to force myself to keep my goals on a somewhat smaller scale. Thanks for the inspiration and here's the mock-up of mine.
Thanks for posting pics on my Vinvanco FB page, by the way. Your thread rules.
Post by wirepuller on Sat Oct 22, 2016 5:18 pm
Thanks Poochie. I have to say, I found a pic of your van 3-4 yrs ago and it was one of a few that made me venture down this road. I can't wait to see your build!!
WP
Poochie
Post by Poochie on Tue Oct 25, 2016 7:46 pm
I'm just at the part procurement point and am going back and forth in my head about the drivetrain. I'm obsessed with the idea of setting the engine back far enough to have a bench seat up front, like a Corvair or VW Van. There was a guy named Jimmy Shadow who built a Ford Econline like that but it seems to have disappeared before it was finished. I also have to be very careful about the 5" body drop I'm planning, as I'm 6'5". I want the bench seat to mount towards the backside of the relocated front wheel wells. The options I'm weighing are an LS/AOD or an Ecotec 4cyl with a five speed auto (Pontiac Soltices and Saturn Skys came with these in a RWD configuration). They put out 175 hp in stock normal aspirated form and the cars they came in were significantly heavier than my Econoline. My feeling is the Ecotec would be more compact and likely give me engine setback, allowing for the bench seat. I'm prepared to trade the entire lower half of the cargo area for front cab comfort. Anyway, the goal would be to mount the drivetrain as low and far back as possible and run a shortened driveshaft/CV to the 9" rear I have for it. I'm going to pattern my frame build off of Steve Luckett's 5" body drop with his guidance and the help of my friend who happens to be a solid fabricator. Going Mustang II and planning RideTech shock Waves on all four corners. Not feeling the need to lay rocker but would like to get the ride height as I have it in my mock up. I'm wanting the van to look a bit roachy, leaving the original paint (yes the paint is original) and hand lettering, also done when it was new). I'd like rear cargo floor to be raised, covering engine trans and all mechanicals, leaving me a functional cargo height of 2-3 feet, like a VW Transporter, only fully enclosed. As for the front cab, I'd like to keep the floors as flat an low possible. I'd like to ditch the doghouse altogether, if possible and perhaps duct to a large radiator directly behind the bench seat. Of course, I'd need to solve for a cooling system. This probably sounds nuts, but that's what I hope to accomplish. I figure talking to as many guys who have done it or are doing it makes sense. And advice or insight is most appreciated.
Post by wirepuller on Wed Oct 26, 2016 7:20 am
I gave pause to an ecotec too, great little engines!  A body drop is certainly going to eat up cabin space, are you sure you need to body drop it?  Mine is not and I can lay rockers.  I think you would just need to set the IFS in the right spot for ride height up front and then put in a big CNotch for the rear.  Since you want to deck the back like the V-dubs, this will provide a good base for the platform.  Something to think about.  I don't think you can ditch the doghouse altogether, but you may be able to incorporate the bench seat up front to be part of the engine cover, and then have a smaller access panel that lifts behind the bench seat to gain access to the engine.  Something like Hibmacronen did, but without the fancy breaks and bends....and the bench part would be flush across....make sense?
I am planning to set my engine(hopefully a 2JZGTE!!) as far forward as possible to gain space for 4 seats in the back, in case I want to take the whole famn damily cruisin someday.
You've got some great ideas brewing there, keep planning and thinking it through but start a build thread so we can comment on your progress/problems!
Keep going!
WP
Post by wirepuller on Fri Oct 28, 2016 7:14 am
Been researching how to make bomber seats.  I plan to put four bucket seats in the van and one bench seat over the IRS.  I've got the mock-up complete.  I plan to bead roll the pinstripe into the seat and the straight lines are just stiffener beads.  I'm going to dimple the holes I have drawn in and I am going to make simple padded seats covered in Mexican blankets.
I also started collecting more parts, and I've deviated from my air ride plans.  I've been talking to a local guy who's big into the air ride and I've decided to use a Slam Specialties 3/8" manifold, and I won't be running copper now, but the flexi-hose.  I'm not sure how I feel about this yet, but he has assured me the new style connectors hold air.  I couldn't entirely toss the copper lines in the trash, so I think I may sleeve the flexi-lines in the copper pipe, just for looks.  Here's the manifold.
WP
TBukit
Number of posts : 30
Registration date : 2017-02-20
Post by TBukit on Wed Mar 22, 2017 7:26 am
This thing looks awesome. Good job. Did you finish the bomb tank?
    Current date/time is Sat Jan 20, 2018 5:03 pm
