    4link front end
    score602
    score602
    Number of posts : 140
    Registration date : 2010-04-05
    4link front end Empty 4link front end
    Post by score602 Tue Apr 17, 2012 6:55 pm
    looking to ditch the front leafs and bag it, any info/pics of a 4link or 3 link?
    was going to monoleaf it with a air shock but would like to see if anyone have gotten rid of the leafs all together
    thanks fellas!!
    Number of posts : 134
    Registration date : 2011-02-26
    4link front end Empty Re: 4link front end
    Post by wildbillinva Wed Apr 18, 2012 2:44 am
    Rolling Eyes
    4link front end DSCN1937
    4link front end DSCN1935
    4link front end DSCN0958
    this is what i'm going to try, it will have a "watts" link to keep it centered. just have to find more time to work on her.
    score602
    score602
    Post by score602 Wed Apr 18, 2012 3:23 am
    wildbillinva wrote: Rolling Eyes
    That looks great! Would triangulated upper arms work with a panhard bar??
    Post by wildbillinva Wed Apr 18, 2012 7:11 am
    i don't see any reason why it wouldn't work. i just wanted to try a watts link to eliminate most of the side to side movement.
    score602
    score602
    Post by score602 Wed Apr 18, 2012 10:57 am
    Yea that's true, You think going that route will cause too much side to side? Any pictures of how your mounting the front bars to the frame?
    Post by wildbillinva Wed Apr 18, 2012 11:34 am
    4link front end DSCN1021
    4link front end DSCN1017
    4link front end DSCN1020
    i was more concerned with using two different length panhard bars on the front and the rear, because of the rear being tubbed.
    4link front end 03-20-10009
    score602
    score602
    Post by score602 Wed Apr 18, 2012 11:43 am
    That's a real nice setup! Did you make that block where the front bars bolt up to at the front spring mount? That's the stock mount correct? Sorry for all the questions!!
    Post by wildbillinva Thu Apr 19, 2012 10:13 am
    ask away. yes i did make the pivots. i went to a local 4x4 shop and picked up a pack of poly bushings then made the blocks to those diminsions. it is mounted to the stock front spring perch. i used 4140 pre heat treated steel from a scrap shaft at work. it is Rc 30. tough, but not brittle. since i'm not able to work on my van at the time, it still feels good to talk about it Smile the bars are 1" dia. 1/4" wall 4140. i still need to make the jam nuts, among other things.
    wildbillinva Very Happy
    Number of posts : 2067
    Post by sasktrini Thu Apr 19, 2012 11:18 am
    Wild Bill, that looks great!
    I kind of wonder about fabbing a bolt-on bracket through the leaf spring u-bolt holes, rather than welding... Actually, I wonder about a lot of stuff, and my brain is full of thoughts... bottom line is I like what you are doing!
    Post by wildbillinva Fri Apr 20, 2012 4:38 am
    sasktrini wrote:Wild Bill, that looks great!
    i was originally going to do an axle over spring, that's why the plate is on the bottom of the axle, but after i mocked it up, i didn't like how close eveything was so i decided to bag it instead. i also thought about doing a bolt on batwing, but decided on welding instead. i plan on adding a bolt on secondary bracket with the lower bag mount, incase of catastrofic faliure. if one of the welds would break due to running over something in the road, at least my axle would stay under the van till i can get stopped, i hope Smile
      Current date/time is Thu Mar 28, 2024 9:40 am
