    700r4 trans question
    Bear
    Bear
    Number of posts : 849
    700r4 trans question Empty 700r4 trans question
    Post by Bear Tue Apr 17, 2012 4:54 am
    are the 700r4 trans the same in mid-size trucks as the full size ?
    Number of posts : 1868
    700r4 trans question Empty Re: 700r4 trans question
    Post by HandiVanMan Tue Apr 17, 2012 5:03 am
    They would be the same transmission but the transmission in a full size would probaly be built more heavy duty for hauling & towing.
    700r4 trans question Empty Tranys-yes
    Post by Twinpilot001 Tue Apr 17, 2012 5:44 am
    I also do believe the 700R4 trannys are the same -I will caution as ive read about the later models=updated -that replaced the 700's =like a 4l80E=?? They have no spedo drive as are electric spedos- and the tailshaft kit thats available from some aftermarket sources to make them a mechanical type spedo is aroung 450-500 bucks alone. Its is a heavier Duty trans than the 700 yet the 700 can be updated with heavy duty parts to be same also.
    Bear
    Bear
    Post by Bear Tue Apr 17, 2012 7:06 am
    reason i ask is my trans has no top bolt hole like a t-350 it don,t look rt to me i will post a pic latter
    Number of posts : 890
    Post by jrinaman Tue Apr 17, 2012 7:44 am
    http://www.rowand.net/shop/tech/automaticoverdrivetransmissionswap.htm this article might be helpful. top bolt?? the standard chevy pattern has 6 bolts. i did have a couple work trucks, c60, that had a 7th bolt centered on top. if thats what you meant by top bolt, forget it. most blocks dont evan have the bolt hole or evan enough metal to drill and tap.
    Bear
    Bear
    Post by Bear Tue Apr 17, 2012 10:32 am
    yes that is what i mean no top trans bolt hole my 350 motor has the bolt hole for it if the trans did.
    Bear
    Bear
    Post by Bear Tue Apr 17, 2012 5:52 pm
    6 bolts holes on trans 7 bolt holes on motor700r4 trans question 00314
    Post by HandiVanMan Tue Apr 17, 2012 8:05 pm
    Don't worry about the 7th bolt hole. It will work fine.
      Current date/time is Fri Apr 19, 2024 5:29 am
