MY 61 ECONOLINE P/U IN PROGRESS
Number of posts : 355
Registration date : 2010-05-30
Re: MY 61 ECONOLINE P/U IN PROGRESS
Post by toad on Wed Dec 08, 2010 1:11 am
More.....
Post by Guest on Wed Dec 29, 2010 10:44 pm
Hey everyone. Sorry for the lack of updates. Been slow going, this year, but I did fire up the engine on the day after Xmas. And when I say fire up, I do mean FIRE!
About 3 minutes and 24 seconds into the run, my transmission (that I rebuilt myself) got so hot that it melted and blew out the trans cooler hose. As if that wasn't bad enough, the scalding hot ATF just happened to spray directly onto the glowing Orange headers on its way to me, my wife, and my friend. But about a thousandth of a second before it reached is, it ignited into one huge fireball! Oh, did I mention that this was in my garage? Luckily nobody was hurt and the fire extinguisher was at my feet, (just in case). I got it all on video too! I will try to post it later. Good news is the motor sounded great , but what a mess! Here is some aftermath pics. Enjoy. Crying or Very sad [img][/img] Laughing [img][/img][img][/img][img][/img][img][/img]
Number of posts : 672
Post by texasjohn on Wed Dec 29, 2010 11:06 pm
NOOOOOOOOOOO!!!!! sounds lime my luck. Glad your alriight
Number of posts : 3736
Post by Digz on Thu Dec 30, 2010 5:30 am
Glad you are all okay ,, very scary for sure ! I had a F/E handy on my first start up too,, just in case.
Post by Guest on Thu Dec 30, 2010 5:45 am
LETS SEE IF THIS VIDEO WORKS. http://www.youtube.com/watch?v=mXgulm2b6zU
Number of posts : 3022
Post by RodStRace on Thu Dec 30, 2010 8:11 am
YeeeHahhh!!!
Thanks for posting, hope it all cleans up well. That powder is caustic, get it all off ASAP!
Number of posts : 7983
Post by dix on Thu Dec 30, 2010 12:37 pm
glad to see no bone was hurt. im sure you will be back on the sadle soon. ( be safe)
Post by G-Man on Thu Dec 30, 2010 12:51 pm
Also glad no one was hurt, just a small set back. Keep those pic's coming
Post by Guest on Thu Dec 30, 2010 2:52 pm
Got the bulk of the mess cleaned up last night. It's not bad at all. I'm pulling the trans 2nite and taking it to my transmission shop that I use for my customers cars. No more trans rebuilding for me! I also finally named the truck " El Cohetero" which means fire maker in Spanish. I knew a name would come eventually! Here's some after cleanup pics.[img][/img] Embarassed [img][/img][img][/img][img][/img][img][/img]
Number of posts : 1781
Post by Van Halen on Thu Dec 30, 2010 4:31 pm
Crazy!!
Post by Digz on Thu Dec 30, 2010 5:03 pm
Wow that cleaned up nice ! Whats the story/source on your accessory drive?
I'm liking that. Idea
Post by Guest on Thu Dec 30, 2010 5:28 pm
Digz, I found it on egay a while back. I pain $137 with shipping from this guy - thundrchicknauto@wildblue.net - I have recently seen one set that has a v-belt groove at the back for possibly power steering. Google gilmer belt drive, and see if you can find anything. Mine worked for the whole 4 minutes! Ha ha!
Post by Guest on Sun Jan 16, 2011 7:35 am
Finished the exhaust last night. I can barely lift my arms this morn. Sucks working on the ground. Should be able to "re-fire" it this afternoon if it stops raining outside. No torque converter installed this time! Just want to get the engine running then hook up the trans.[/img] [/img][img][/img][img][/img][img][/img][img][/img][img][/img][img][/img][img][/img][img][/img]
Number of posts : 1860
Post by savage on Sun Jan 16, 2011 8:12 am
We all have our fingers crossed for you too.
Post by Guest on Mon Jan 17, 2011 7:19 pm
Well, fired up the engine again this afternoon, and............................It ran great! It's still loud as hell even with the mufflers on. Which is fine with me, I just like to be able to hear any engine noises if they occur. Only problem was it was running rich as hell. I'll have to put a liquid filled fuel pressure gauge on it to get accurate fuel pressure and then probably have to adjust the float level due to the angle of the engine.
All in all it was a success! I drained the oil and it looked great with no scary metal pieces in it. Whoo! My stomach was knotted up the whole time! Next step, check everything over real good, adjust the valves and look at the valve train while I'm in there, and try to tune it............ cheers
Post by Digz on Mon Jan 17, 2011 7:37 pm
Yeehaaaa.. nothing to make ya sweat like a fresh engine started.!!
Post by Guest on Fri Feb 11, 2011 4:42 pm
Well, got a speedo out of my old junk cutlass, and melted some lexan over the original dash bezel to make a mounting plate. I then cut a hole in the middle and epoxied the speedo in place. Then painted it, made a couple of support brackets and ta-da! One custom speedo. Also made an adapter plate to mount the cutlass steering wheel. Almost done wiring the whole thing. Man, wiring sucks! Also started on the fuel tank mounting. Hopefully I will finish it this weekend along with wiring. Here's a few pics of the progress. [img][/img][img][/img][img][/img][img][/img][img][/img]
Post by G-Man on Fri Feb 11, 2011 4:45 pm
As always very nice work!!!!
Number of posts : 575
Post by austinmodhouse on Fri Feb 11, 2011 4:50 pm
very cool indeed! can't wait to see this in person.
Post by Guest on Fri Feb 11, 2011 4:55 pm
G-Man wrote:As always very nice work!!!!
Thanks, G-Man. I sure like your motor. Yur gonna have to hold on tight when you gas that thing!!! How close do ya think you are to driveable?
Post by EconoCarl on Fri Feb 11, 2011 5:00 pm
I don't think you're gonna' have enough speedometer for all that motor! affraid
Hope to see it come April.
Post by G-Man on Fri Feb 11, 2011 8:26 pm
I'm hoping for spring on taking it for a spin , but still a long ways to go. You look like it will be ready for paint soon. What Color will it be again
Post by Guest on Sat Feb 12, 2011 6:37 am
G-Man wrote:I'm hoping for spring on taking it for a spin , but still a long ways to go. You look like it will be ready for paint soon. What Color will it be again
Well, now I really don't know anymore. Gonna be black for a while so I can soak in the whole truck when its driveable, so I can look at it from afar, and in different back drops. Ya know, see if it looks right to me or not.
I guess the answer is, I dont know now. Lol.
Post by Guest on Sun Apr 03, 2011 9:05 am
Finally got it together enough to make it to the Roundup! What an incredible time! Also got to meet some of you guys there. Lovin life! : [img][/img][img][/img][img][/img] Smile [img][/img]
Number of posts : 1370
Post by BILLS66 on Sun Apr 03, 2011 2:41 pm
That is so cool hows it run and drive? Bill
    Current date/time is Sat Jan 20, 2018 12:43 am
