Just wondering if the radiator is the same size used for a 65 250 engine as the 350 engine.I am doing a v8 swap and was wondering if the radiator supports for the 6cylinder needed to be updated for the new v8 Can I use the same radiator for both 6 an 8 cylinder
Radiator size for 6 and V8
teamthunder7- Number of posts : 13
Registration date : 2012-02-17
- Number of posts : 12218
Re: Radiator size for 6 and V8
So as I see in the pics I would need that crossmember also right for the second gen radiator
The 6 cylinder has a normal downflow one bolted in, but that V8 crossflow type sits WAY down there under the seats, it has no radiator cap on it and requires a surge tank to fill the radiator and get the air out of the system....and it uses an enormous shroud and a clutch fan to be the coolest radiator system on an Early Chevy/GMC van.......
Don,
Can you please PM me or email me, or post with detailed, exact as possible measurements of that radiator? Core size and overall size too including tanks. I would really appreciate it. Thanks so much.
,,,,,,here you go, Joe,,,,,
https://vintage-vans.forumotion.com/t28027-need-detailed-exact-measurements-of-v8-radiator-2nd-gen#116766
