Steering Drag Link ???
Number of posts : 511
Re: Steering Drag Link ???
Post by pan58head on Tue Oct 30, 2012 2:54 pm
We have winner!!!!! Talked with moog today and the es358r and es358L have the same size and taper pin as the the es409L. I'm going to order a pair and figure length to buil the rod!!!!!! winner winner chicken dinner Bob
Number of posts : 1723
Post by m1dadio on Tue Oct 30, 2012 7:02 pm
Good job!
those are the same parts that you gave the NAPA numbers for on an earlier post.
They fit a 65 to 70 C20 3/4 top PU and the C30 1 ton PU.
They have a 5/8 x 18 thread and are 7.44" long each
So the way i see it if the drag link is 28" like Don says then you need about a 16" long sleve which will give about 1.5" of each tie rod threaded into it.
Sleves come in every lenght up to about 60" long.
So call the MooG guy back and tell him you need a 16" long sleve with .625 X 18 threads both left and right. maybe he can give you an exact fit.
M1d
Number of posts : 1484
Post by Scott on Tue Oct 30, 2012 7:39 pm
Why not just buy a new one for $32 bucks?
Post by pan58head on Wed Oct 31, 2012 4:56 pm
Scott, would love to but the only ones available are for 2nd gen and the tie rod is 180 degrees from the 1st gen.
M1d Yeah These are the same , but in a moog number. I've had bad luck with napa suspension parts. I found a place to get nice aluminum rods already threaded, I think this is how I'm going because I need a tie rod also mine is bent Bob
Number of posts : 820
Post by mbasaraba on Tue Nov 13, 2012 5:37 am
pan58head wrote:Scott, would love to but the only ones available are for 2nd gen and the tie rod is 180 degrees from the 1st gen.
Bob,
Do you have the part number for the replacement tie rod ends by chance and where you are getting them?
I need to replace the tie rod ends and make the replacement drag link also.
Post by pan58head on Tue Nov 13, 2012 6:26 pm
Matt the tie rods are moog es358l and es358r, I got them from rock auto, I'm waiting on my 6061 aluminum tie rod to come in then i will try to post pictures of the whole unit Bob
Number of posts : 11492
Post by donivan65 on Tue Nov 13, 2012 6:57 pm
The thread sizes are the differences in those tie rods,,,,,the 409 is 11/16",,,,,the 358 is 5/8" and they come in left and right handed types,,,,,seems to me if you got 2 of the R type tie rods,,,,it would be easier to find a pipe with those threads in it or tap new threads in rather than trying to mess with that left hand threaded tie rod,,,,,a sleeve would have a left hand and a right hand thread in it, but it seems it would be easier to deal with 2 right hand threaded tie rods......
Post by pan58head on Wed Nov 14, 2012 7:20 am
Yeah Doni that's why I went with the 358's one is left and one is right. I bought a race car rod that is 16" long with 5/8 left hand threads in one end and 5/8 right hand on the other. This way I can adjust it in and out to compensate for lowering and make the wheel straight. With the two right threads you would have to take one end of the rod off to adjust it. With a left and right you just loosen the jam nuts and turn the rod. I'm waiting for the rod to show up and then I will post a picture
Last edited by pan58head on Wed Nov 14, 2012 7:22 am; edited 1 time in total (Reason for editing : duplicate)
Post by donivan65 on Wed Nov 14, 2012 9:35 am
The point is left hand threads make things more complicated if you are looking for parts and tools,,,,,nobody needs to ever adjust a drag link link once you set up correctly,,,,,but you have options now on whatever way you decide to go...left, right, or welded........it's all good.......
Post by pan58head on Wed Nov 14, 2012 3:04 pm
Yeah, I understand that not everyone has access to the the tools to make these parts. I have it all figured out to be able to buy all of the parts over the counter. Parts should be here by friday Bob
Post by mbasaraba on Mon Nov 19, 2012 6:51 am
pan58head wrote:Yeah, I understand that not everyone has access to the the tools to make these parts. I have it all figured out to be able to buy all of the parts over the counter. Parts should be here by friday Bob
Bob can you provide the info for that tube?
Post by mbasaraba on Mon Nov 19, 2012 7:19 am
Are the tapers different size from the actual tie rods? It is crazy that this ES358L and R is over 2X as much as the ES350L and ES370R which are the tie rod ends. I bought these for $15 each on eBay but the 358s are $40 each.
Post by donivan65 on Mon Nov 19, 2012 11:33 am
The tapers are correct,,,,,the length, thread sizes and type are different,,,,,and prices are all over the place,,,,,like $15 to $60,,,,,,,
Rare Parts Inc
Post by Guest on Mon Nov 19, 2012 4:54 pm
Rare Parts,inc 209-948-2851 Stockton,CA 95203 heavy duty part #RP27487 225.00 very nice thicker than original piece great people to deal with,only place that makes them,to my knowledge. This is for the 64-66
Post by pan58head on Mon Nov 19, 2012 5:28 pm
Matt the rod is a 16" tube from any race car shop. I have the unit assembled but , I just finished a 40 work week in three days, I will try to post picture tuesday. As for the 358 r and 358l, I bought them for $25 each from rock auto.
gotavan
Number of posts : 242
Post by gotavan on Sat Dec 01, 2012 1:47 pm
I bought a few NOS ones, years ago I got them at my GM dealer they were less than 25 bucks New. Years later I bought 7 NOS ones on ebay for 46 bucks, I sold one 2nd gen for 75. One way to tell if it's 1st or 2nd gen is the position of the grease zerts 1sts are usually up or down and 2nds are usually in the ends front or back.
here's a pic of 1 1st and 2 second gen. these are GM NOS aftermarket may be different.
Post by pan58head on Thu Dec 13, 2012 10:54 am
Sorry guy forgot to post a picture of the finished link Bob
Post by m1dadio on Fri Dec 14, 2012 7:21 am
Nice job on the adjustable drag link!
M1D
Number of posts : 1293
Post by Lazarusvan on Tue Nov 24, 2015 11:49 am
Just read through this thread. Has anyone found a stock replacement for since this time for a 1st Gen drag link?
Xelmon
Number of posts : 343
Post by Xelmon on Tue Nov 24, 2015 1:07 pm
I've been experimenting. The ES150L and ES150R seem to be good candidates.
They are 1 ton / 7/8" stud tie-rod ends used in the 80's Dodge W250/W350. The taper is a reasonably good fit, and Moogs are about $30 a piece, less for other brands.
I shall report back later as I am also waiting to get in an ES2234R, which is another 7/8" stud tie-rod end.
Post by pan58head on Tue Nov 24, 2015 6:55 pm
The numbers of the tie rods I list are a direct fit, just have to buy a race car bar with left and right threads. I think my aluminum bar was like $20
AzDon
Number of posts : 322
Post by AzDon on Sat May 27, 2017 9:29 am
I just finished this conversion and it looks just like pan58's picture..... Uses Es358 left and right ends and 17"x 5/8 threaded tube from Summit..... Ended up at 27.5" pin-to-pin to center the steering box, which is 1/2" shorter than stock....
    Current date/time is Fri Jan 19, 2018 5:15 am
