+4
cl350rr
8 posters
    O/T Fiberglass ?
    Number of posts : 1388
    O/T Fiberglass ? Empty O/T Fiberglass ?
    Post by wideload Thu Feb 16, 2012 10:42 am
    I've got a fiberglass project under way and need to know if there is anything that you can coat a piece of wood with to keep fiberglass from sticking to it. In needs to be something that will spread smoothly or soak into the wood(maybe some type of oil???).
    I've been using aluminum foil but cant get it as smooth as I'd like to.
    Number of posts : 466
    O/T Fiberglass ? Empty Re: O/T Fiberglass ?
    Post by Sy Hollinshead Thu Feb 16, 2012 11:22 am
    When they make moulds for fibreglass, they apply a special wax to the mould to prevent the fibreglass from sticking to it. I would think this would be your best bet.
    Post by wideload Thu Feb 16, 2012 12:28 pm
    Something like that is what I'm looking for Sy. My mold is made from wood so some sort of wax should work. Just need to find out what kind. Thanks!!
    Number of posts : 3046
    Post by RodStRace Thu Feb 16, 2012 12:32 pm
    Stop by the same place where you got the 'glass supplies. They should have "Mold Release" or something similar.
    In a pinch, you could probably melt candle wax on the wood. To smooth it, use a heated butter knife.
    Even a good car wax (not cleaner wax, just straight wax) applied a in few coats should do it.
    cl350rr
    cl350rr
    Number of posts : 287
    Post by cl350rr Thu Feb 16, 2012 2:47 pm
    If the wood is smooth (not alot of open pores for the resin to grip) you could use paste wax
    Number of posts : 165
    Registration date : 2011-07-28
    Post by Zuffen Thu Feb 16, 2012 10:12 pm
    I've seen PVA adhesive (the white stuff) use as a release agent.
    I once rented a car to an advertising company to shoot a commercial.
    The car was dark green and half way through they wanted a white one (it was a 911 Porsche so they aren't too thick on the ground).
    We painted it with PVA glue, let it dry then painted it white.
    Once the ad was finished we used a pressure cleaner to blast away the paint. Not a spot of white.
    I belive this was how they took the white paint off the Lambo in Cannnonball Run.
    Post by wideload Fri Feb 17, 2012 4:59 am
    Thanks for the replies!!!! Now I need to do some experimenting.
    Number of posts : 864
    Post by Casimier Fri Feb 17, 2012 5:26 am
    Hey Wideload
    I use spray wax...endust..as a release agent...
    also cleans your hands and has the lemony smell to it!
    Smile
    Jim
    Post by wideload Fri Feb 17, 2012 5:56 am
    Thanks Jim! That will be my first experiment.
    SDEconoTruck
    SDEconoTruck
    Number of posts : 310
    Post by SDEconoTruck Fri Feb 17, 2012 9:43 pm
    Hi Mike,
    I do a lot of mold building and work with molds
    in my shop. As been mentioned you need a parting
    agent. Assuming your wood mold is smooth and
    polished, and you are using basic polyester tooling
    resin, you will need to do two steps.
    First is wax the mold. Use a true carnuba wax not
    modern spray waxes for cars. Do this three times,
    wax then wipe smoothly after each coat.
    Second is to get some Poly Vinyl Alcohol (PVA) which
    is usually sprayed from a paint gun, or airbrush.
    Shoot 3 coats, allowing the PVA to dry completely
    between each coat.
    After the PVA is dry, then start applying your resin
    work. Some sort of seal or gel coat is recommended
    on the mold/PVA before the glass is put on.
    Best of luck,
    George
    Post by wideload Fri Feb 17, 2012 10:07 pm
    Thanks George. Sounds like you've done this a few times.
    SDEconoTruck
    SDEconoTruck
    Post by SDEconoTruck Sat Feb 18, 2012 5:47 pm
    You're more than welcome Mike, I understand you can get
    PVA in a spray can from Paint Suppy type shops. I molded
    some custom carbon graphite seat hinge covers for my Econo:
    O/T Fiberglass ? Seatbu10
    O/T Fiberglass ? Seatbu13
    O/T Fiberglass ? Seatbu14
    Kind of a combo of the old and the new.
    Hope this isn't considered a hijack! Laughing
    Molding parts comes in handy for mods to our Econolines!!
    Best Regards,
    George
    Post by wideload Sat Feb 18, 2012 6:39 pm
    Those are sweet George. I'll check on the PVA sometime this coming week. Think I'm going to try the endust that Casimier suggested on a practice piece also. My project is small with no complicated bends.
    Number of posts : 2067
    Post by sasktrini Sat Feb 18, 2012 10:03 pm
    Nice!
      Current date/time is Thu Mar 28, 2024 6:20 am
