what is the correct brake bleedind sequence???
bleeding sequence
- Number of posts : 8728
bleeding sequence
- Number of posts : 12218
Re: bleeding sequence
Do the wheel cylinder that is furthest away from the master cylinder so that the line has no air in it,,,,then do the next furthest one and so on,,,,,if you have a 2 line master cylinder, do each furthest one on each line then do each closer one,,,,,
