My rear springs, brackets and mounts were completely shot. Scary shot. So, I cut everything out and a friend has been helping fabricate really beefy new ones. In the process we also cut out the rear fenderwells larger than needed, partly due to rust, and partly with idea of one day sticking wider tires back there.
However, afterwards, I realized that my 205 tires are only about 1" away from the u-bolts/springs, so probably the widest I could go is 215 or 225 anyway... unless I relocate the springs to under the frame rails (instead of next to).
Has anyone done this? I'm not really interested in sticking big meats under the van, but I figure now's the time to do it if it might add to resale value. My friend says it's not a big deal work-wise.
Thoughts?
Here you can see how close the tire is to the springs (and how bad the mounts were). It has a 302, 3spd and posi 9"... and will see the drag strip 2-3x/year for fun. The rest of the time it's just a fun van.
Thoughts?
