Hello Econoline crowd, Hoping you can help me out. using a 9" ford rear end out of a 67 econoline is my 64 g series van(I know ford in a chevy) Just curious where you are getting replacement e brake cables Thanks Bob
e brake cables for 9" ford
Big W- Number of posts : 3282
Re: e brake cables for 9" ford
That's ok pan58head....I put a chevy in a Ford...it's all good, but don't tell anybody
Hey Big W, he upgraded his Chevy by adding a Ford rear end. LOL
Big W , I love it it must really piss off ford guys. I put a 400 pontiac is a 4wd dodge truck years ago just for fun. The only real reason for the 9" is that I don't think the stock rears will hold up to my supercharged ls. Plus I've had this rear end for 10 years and it never really fit anything I was building. It's going to be almost bolt in to the 64 B
Last edited by pan58head on Fri Nov 04, 2011 6:15 pm; edited 1 time in total (Reason for editing : spelling)
Old Skool- Econoline Guru
- Number of posts : 1306
I forget the year change right now, but its as easy as a single E brake cable versus the 67's two E brake cables. The earlies used a single cable and the mounts welded on the truck for the cables are welded in a different position than the 67's dual cable mount location. So,, if you have the single cable setup in your truck, simply remove the cable from your small rear end, and put it into the 67's backing plates.
Its easy, just use a small hose clamp to compress the barbs on the E brake cable ends so you can pull it out.
Then all you need to do is push the ones you want into your 9" backing plates that you already removed the cables from. I cant remember but I think the 64's used the dual cable setups also..
vic
picture brain fade again..
vic
Thanks for the response. I wish the 9" ford ones where there, I cut them off 10 years ago. But I think I can use the ones that on my 64 gmc van now. hopefully later today I will get set the rear end in the van and check Bob
TOO much rigamaro and hassle. I MAY have one extra set (two cable setup) extra for sale. Its one of those kick myself in the pants and learn to keep an eye out for. I have four rear ends here needing them to be complete ones. Will look when I get a chance.
vic~~~~~~~~~~~ lately a good thing to remind me,,,,
Old sckool, you wouldn't believe this but the ones on my 64gmc fit right in the 67 ford backing plate. I hate to say this but ford built this rear end to fit into a g series van Bob
That's great!!
How about the length and the rest of it,, is it a done deal?? Hoping so.
vic
vic
Yeah, the other end is still in the stock brackets. like I said this rear end was made for the g series Bob
kool...glad it worked out for ya. Another early has been saved from rolling away..lol.
