by SDEconoTruck Mon Oct 31, 2011 7:07 pm
Hey Jeff,
You are onto it: "Or is grounding it somehow completing a
circuit to the gauge through the gauge cluster?"
Hard to visualize this type of circuit. Two things are
worthy of mentioning. First, there is just one wire going
to the gauge, and the ground/return "wire" is merely the
tank/body/dash/ cluster metal itself. Second, the gauge
can be affected by the voltage of the entire body (ie.
grounding the wire from the gauge-to-sender at the sender
end, to the body.) That would be like a full tank on the
sender unit.
You can momentarily hit your gauges with 12 volts, BUT I
emphasize MOMENTARILY, as the gauge reaches "full" or "hot"
you better shut off the juice to the gauges! They handle
5 volts just fine +/- a couple volts.
I recommend doing the battery test I described, using "AA"
batteries, NOT the van's battery, on your gauges, as it
builds confidence.
Sounds like you just need to sort out the wire from keyed power
(fuse block) connecting it to the CVR (constant
voltage regulator) and having two wires come from that to
your Temp and Fuel gauges. Metal contact of the two gauges
to the metal dash completes their electrical connection.
Varying the resistance in that circuit (rheostat in the
fuel sender) will change the constant voltage going through
the fuel gauge, thus making the pointer/needle change
position. Whew!
Please ask more questions on this, as I can imagine how
frustrating it would be to accidently wreck a gauge or two.
(Don't ask me how I know! HA HA)
George
Oh, one last thing: I cannot emphasize how important it is
to properly ground the ENTIRE vehicle- These old cars live/die
by this. I've seen so many missing one of the ground links.
Usually the ground from the block to the body is missing. And
be sure this ground is at the opposite end of the motor from
the other ground going to the block, as this seems to make a bit
of difference too. I wrote about the ground paths in that write
up.
