    240 ci. gas pedal assembly
    240 ci. gas pedal assembly Empty 240 ci. gas pedal assembly
    Post by Guest Sat Oct 15, 2011 7:19 pm
    i was wondering if anyone out there might have or know where to buy a gas pedal assembly from a 240 ci. engine. i have a new 200 ci. engine that im installing into my 64 DCW and i need to convert it into a throttle cable set-up.
    jeff in portlan, or.
    240 ci. gas pedal assembly Empty Re: 240 ci. gas pedal assembly
    Post by Guest Sat Oct 15, 2011 9:05 pm
    you can use this one: http://www.reidsrodparts.com/images/int/_notes/R8504.jpg located here: http://www.reidsrodparts.com/INT12.html There are two so get the cheaper one. They are exactly alike. All you need to do is have a cable made to fit or buy a Lokar cable which usually costs more.
    Post by Guest Sat Oct 15, 2011 9:07 pm
    I just realized you are putting it on a 200 ci. I have that same pedal for my 200 ci and for my 240. They are great and look good too.
    Number of posts : 2198
    Post by EconoUSAparts Sun Oct 16, 2011 6:23 am
    Vic,aka Old SKool has them. Im all out.
    fmc56
    fmc56
    Number of posts : 553
    Post by fmc56 Sun Oct 16, 2011 8:53 pm
    brokeassgoat wrote:i was wondering if anyone out there might have or know where to buy a gas pedal assembly from a 240 ci. engine. i have a new 200 ci. engine that im installing into my 64 DCW and i need to convert it into a throttle cable set-up.
    Jeff ,
    If yu use the throttle cable bracket from an early Bronco 170 the 240 cable will bolt to it.
    Fred
    240 ci. gas pedal assembly Bronco10
    240 ci. gas pedal assembly Bracke10
      Current date/time is Fri Apr 19, 2024 6:20 am
