    350 Swap into a 68
    350 Swap into a 68 Empty 350 Swap into a 68
    Post by Guest Sun Jul 03, 2011 3:08 pm
    Though my van already has had a 350 swapped into it, the person who did it used the 250 mounts. Is there a crossmember with the proper 350 mounts out there or will I have to custommize my own?
    Also, would a front- or mid-mount plate be a better alternative?
    350 Swap into a 68 Empty Re: 350 Swap into a 68
    Post by G-Man Sun Jul 03, 2011 7:53 pm
    the 250 mount is the same as the v8 mount
    Number of posts : 2625
    Post by savage Mon Jul 04, 2011 5:24 am
    I bolted a 454 to the 1st gen crossmember Shocked
    Post by Big W Mon Jul 18, 2011 7:27 pm
    Flat top '57 Chevy mounts, homemade cross member witch bolts up to stock holes on the frame. It's in a '66 ford but I'm sure you could adapt to Chevy pattern. Engine is a 350 out of a '81 Capri. My oil pan may be different, but that's an easy swap.
    ..350 Swap into a 68 Dsc00136
    ..350 Swap into a 68 Dsc00137
    ..350 Swap into a 68 Dsc00139
    ...Hope I was able to help...
    350 Swap into a 68 Empty 67-70 mounts - factory
    Post by Twinpilot001 Mon Jul 18, 2011 7:36 pm
    Gen 2- chev Gmc V-8 mounts - factory installed-find one .
      Current date/time is Fri Mar 29, 2024 1:30 am
