+4
cculella
8 posters
    Interchangeable Parts
    cculella
    cculella
    Number of posts : 110
    Interchangeable Parts Empty Interchangeable Parts
    Post by cculella Wed Mar 30, 2011 4:06 pm
    So I'm restoring my 65 Chevy Panel van and am wondering what parts are interchangeable from the Chevy Trucks. There are a ton of sites devoted to restoring trucks to factory condition and beyond, not so much for the vans. I know that there are many parts that interchange and even more that are just different enough to not work. So what I am asking is to tap into your collective experiences and see what parts will be easy to get (interchangeable truck parts) and what parts I will have to hunt for (early van only parts).
    Here is a list of some of the parts I am thinking of replacing. Maybe you guys can comment on what's interchangeable.
    - Window regulators
    - Inside door handle and window handle gaskets/bushings
    - Windshield wiper arms
    - Windshield wiper switch
    - Horn Relay
    - Gas tank
    - Headlights and wiring harness
    - Outside door handles and gaskets
    - Anything else you can think of that I will need for a restoration
    Thanks for helping out a fellow vanner.
    - Charlie
    cculella
    cculella
    Interchangeable Parts Empty Re: Interchangeable Parts
    Post by cculella Wed Mar 30, 2011 4:17 pm
    I forgot to add radiators and electric fans to the list.
    Number of posts : 12218
    Post by donivan65 Wed Mar 30, 2011 4:37 pm
    I am running a Honda fan on my 65,,,,,,,best $15 I ever spent,,,,,,i wouldn't leave home without it,,,,,,,,
    Interchangeable Parts Reinva10
    Post by Twinpilot001 Wed Mar 30, 2011 4:47 pm
    Like that fan idea = pulling air from engine area-nice!!
    Post by donivan65 Wed Mar 30, 2011 7:07 pm
    No,,,,,,,,pushing air up from the bellypan to cool down the radiator in 100 degree traffic, blowing the gas fumes out the back of the doghouse and keeping the carb from boiling over after shutting down,,,,,,and on a timer to set it and forget it,,,,,,,,
    Number of posts : 801
    Post by panelmanrd Thu Mar 31, 2011 5:29 pm
    window regulators= van only
    inside handles and bushing=same year truck
    wiper arms, second gens=67/72 chevy truck not sure bout the firsts
    not sure about the wiper switch
    horn relay should be the same year truck or car
    gas tank=van only, 1st and 2nd gens are different
    wiring harness=vans only, universals are not that tough to install
    keep asking I will do my best at answering
    Number of posts : 1778
    Post by m1dadio Thu Mar 31, 2011 6:25 pm
    outside door handle and gaskets and rear chevrolet script and wiper switch see Clark's Corvair on line for many 1st gen parts came from the Corvan.
    All the door rubbers and window gaskets come through steel rubber products I belive, or is it restoration specialties?
    See Wookee for glove box insert and window fuzzies
    you will have to get a little more specific about your engine and trans before
    talking rads and fans.
    front turn signal lights are availible complete new from earlier PU trucks
    insade door arm rests same year pu truck.
    M1D
    veefre
    veefre
    Number of posts : 424
    Post by veefre Fri Apr 01, 2011 12:04 am
    What isn't interchangeable is drum brake parts... such as backing plates. They seem to be unique to the early vans.
    Post by m1dadio Fri Apr 01, 2011 7:36 am
    True; but they can be replaced with disc brakes
    M1D
    Number of posts : 3046
    Post by RodStRace Fri Apr 01, 2011 8:38 am
    Just as a reminder, there are books for this, although they are not easily found or cheap.
    You will need a parts book for your specific vehicle and a Hollander interchange manual.
    cculella
    cculella
    Post by cculella Fri Apr 01, 2011 9:01 am
    Thanks for all the replies, they definitely help. The engine is the 6 cyl 230 with the 3 on the tree manual. I do have the van and truck shop manuals, but they don't really have part #'s just service descriptions.
    Number of posts : 7900
    Post by DanTheVanMan Fri Apr 01, 2011 9:31 am
    $60 for the 12" fan, relay, thermal switch and wiring....
    Originally had a 210-90 degree thermal stat but swapped it out for a 180-160 degree and put in a 190-170 degree switch for the electric fan and wired the fan independently so when you park and walk away and the engine heats up the fan will kick on and shut off on it's own.... One of the best investments I ever made for the van!
    Dan
    Interchangeable Parts Img_2415
    Interchangeable Parts Img_2414
    Interchangeable Parts Qr_cod10
    Post by DanTheVanMan Fri Apr 01, 2011 9:38 am
    Having one of these comes in handy from time to time.....
    Interchangeable Parts Img_2416
    Interchangeable Parts Img_2417
    cculella
    cculella
    Post by cculella Fri Apr 01, 2011 11:48 am
    Dan, where would I go to get a fan setup like that? It looks clean, powerful and efficient. So I would need the fan, the thermostat and where to splice in to make it work.
    Post by DanTheVanMan Fri Apr 01, 2011 2:25 pm
    veefre
    veefre
    Post by veefre Sat Apr 02, 2011 12:29 am
    m1dadio wrote:True; but they can be replaced with disc brakes
    M1D
    Yah huh, for a few hundred or even thousand bucks and a LOT of work, lol.
    The drum brakes actually work pretty good, now, at least the front ones. The rears are acting up, a bit grabby, which makes panic stops ... interesting ... will have to figure out why at some point sooner than later. Esp after some dingbat jumped out of a lane of stopped traffic, on a freeway split, over the solid white line, and then slammed on her brakes to re-enter the lane she just exited. The 108 started its rear end skid routine but fortunately she'd pulled back in before contact. Idiot!
      Current date/time is Fri Apr 19, 2024 8:05 am
