    Looking for 302 c4 conversion advise with auto set up
    Donn
    Donn
    Number of posts : 692
    Looking for 302 c4 conversion advise with auto set up Empty Looking for 302 c4 conversion advise with auto set up
    Post by Donn Mon Mar 21, 2011 6:06 pm
    Looking for what other's have used with a 302sb to C4 trans as far as shifters, shifter linkage, cable etc..
    What shifter did you use? did you get the linkage and cable from same company? are you happy with it? How much did it run you? Where did you locate the shifter?
    Any pictures would be great...
    thx
    Donn
    Old Skool
    Number of posts : 1306
    Looking for 302 c4 conversion advise with auto set up Empty Re: Looking for 302 c4 conversion advise with auto set up
    Post by Old Skool Sun Mar 27, 2011 1:01 am
    Donn,,,, I make a cable conversion that gets rid of the shift rod. Its H/D 1/4" cable, air craft type hyme joint ends, adapter bolt for our automatic column shifter arm, frame mount, trans mount, replacement adjustable trans shifter with matching kick down lever.
    vic
    Looking for 302 c4 conversion advise with auto set up 100_1136
    Looking for 302 c4 conversion advise with auto set up 100_1015
    Looking for 302 c4 conversion advise with auto set up 100_0917
    Looking for 302 c4 conversion advise with auto set up 100_1016
    Looking for 302 c4 conversion advise with auto set up 100_1017
    Post by Guest Sun Mar 27, 2011 12:25 pm
    I have seen Vics setup and it is very nice and clean.
      Current date/time is Thu Mar 28, 2024 11:25 pm
