by RodStRace on Thu Mar 03, 2011 2:50 pm
Stock valvetrain, meaning hydraulic and not real big cam.Can't see any X or J between the plugs, probably the 1978 heads. The Yellow looks like it's not covering stock paint, so it's been rebuilt.
The Blue sure looks like permatorque gaskets. Stock was steel shim. Looks like it's been burning oil, check the guides in the heads. I'd hazard at least 20-50K on the engine.
Valves are not super close, so they are not 2.02" intakes. Casting number (4027163) says 77-82 1.78 heads.
http://www.waywardgarage.com/tech/SBchrysler.html
Magnums or even J heads would be an improvement.
Exhaust valve to far left looks leaner (lighter color) may be from heat. make sure the valve job is good. Check the intake for that cylinder to see if there is a possible vacuum leak.
Again, lots of oily deposits, but even. Looks like replacement pistons with the double reliefs. I think stock had a dish, so it may have a bit more compression. A quick check of deck height would help. Coolant looks good (bottom left)
Lots of silicone, some prefer to use all silicone instead of the cork end seals.
cam, lifters and pushrods look stock or close. Ports look untouched.
Sure wasn't a "race" motor with the heat risers open, stock valvetrain and low end stock heads.
