+7
Eagle1
badassbob
11 posters
Window Seals and windshield seal
badassbob- Number of posts : 2
Registration date : 2011-01-06
I have a 68 chevy sportvan 108 and am currently restoring and now getting it painted and need to get info on where to get all of the window seals and weather stipping.
Re: Window Seals and windshield seal
heres some of them, Welcome to the site!!!!
http://www.vintage-vans.com/chevy_parts_dept.html
Hey g-man any good places to get all the door weatherstripping??
I think I have heard donivan say JC Whitney, maybe he will see this post
- Number of posts : 12218
Well,,,,,,,JC Whitney has the stationary glass weatherstripping with the locking splines, There are places like Steele Rubber that claim to have the door weatherstripping,,,,,,
Eagle1- Number of posts : 144
Registration date : 2010-09-18
I just replaced every bit of weather stripping on my 68 90 and I got the windshield gasket from Obsolete Chevy Part # WBLD693
http://www.parts123.com/PartFrame.asp?ZTM=cadeflka&GHOME=www.obschevy.com&TITLE=Obsolete_Chevrolet_Part_Co
I got the preformed door seals from Steel rubber and the look just like and fit like the originals.
http://www.steelerubber.com/
And the vent, front windows and stationary windows, dog house seal door bumpers from
Restoration Specialties
http://www.restorationspecialties.com/
And I got the hinge grommets from GM Direct Part # 12337944 they are the stick on for 3rd gen but for $2.20 they will work (Steel and Restoration want $8.00 a piece
http://www.gmpartsdirect.com/
Yes
Here is what Restoration Specialties has for G10 64-70.
1964-1970 CHEVY VAN WEATHERSTRIP KITS
970219 1964-66 WINDSHIELD GASKET $55.00
WBLD693 1967-70 WINDSHIELD GASKET $85.00
70211555 VENT WINDOW GASKETS $115.00
CVC6470 CHANNELS, DIVISION BARS, BELT STRIPS $110.00
70248472 DOOR WEATHERSTRIP FRONT $75.00
70258572 DOOR WEATHERSTRIP SIDE AND REAR $150.00
60065969 DOOR HINGE GASKET SETS OF 4 $32.00
E715 DOG HOUSE SEAL $2.00/FOOT
AS1216 FIXED WINDOW GASKET & LOCKSTRIP $2.75/FOOT
VSG001 POP OUT WINDOW GASKET $1.50/FOOT
CUSTOMER TO SPECIFY EXACT APPLICATIONS
Wow Thank$$$ Guess I got some work to do!!
One size fits all, They are about .0625 to big on the front doors , but I used a hypodermic plunger with black silicone in it and I can't even tell.
Do you guys think I need a premolded weatherstrip for the side and rear doors? They seem pretty straight forward wonder if I need to spend $150 or just get a roll and make my own>?
The left side cargo doors use a metal retainer that is built into the ends of the seal to help hold them in place. as effective as the adhesive is I dont know if you would need it ? But the repop seals are an exact fit with the corners all made, pretty easy to use. JMO
Good enough for me...
Thanks guys you have been a really good help Ill Post before and after pics when i get it out of the body shop
I just realized Steele rubber is 15 min. from my house going to get my door seals tomorrow!!!
Don't want to hijack the thread but Ive never pulled a windshield before...Is this something that a rookie can do without breaking it? Do you need special tools? I thought this was something that maybe an auto glass installer might have to be paid to do?
Im moving towards painting the Magic Bus and I really need to get the windshield and side door glasses out and get new seals in to make the job look good..any help greatly appreciated..
- Post n°19
IF,,,,,,,the rubber weatherstripping has not hardened up too much, just take a razor knife and cut a small patch out of the rubber starting on the glass and working outward,,,,,,you just need remove enough that is covering the glass,,,,,, just get the rubber off the glass,,,,,,,so basically you remove about a 1/2 inch of the rubber so you can push the windshield out, then pull off the weatherstrip. Now if the weatherstrips are soft, fold them down from the body on the inside and push them and the glass out
- Post n°20
donivan65 wrote:IF,,,,,,,the rubber weatherstripping has not hardened up too much, just take a razor knife and cut a small patch out of the rubber starting on the glass and working outward,,,,,,you just need remove enough that is covering the glass,,,,,, just get the rubber off the glass,,,,,,,so basically you remove about a 1/2 inch of the rubber so you can push the windshield out, then pull off the weatherstrip. Now if the weatherstrips are soft, fold them down from the body on the inside and push them and the glass out
Doesnt sound too bad for the removal... How about the re install? And the side windows..not too bad?
Im just a little concerned about the windshield and cracking it..they seem to be hard to come by in the midwest..and a little expensive..?
- Post n°21
Check out pages 11 and 12 of VanAgains van,,,,,,,The whole idea is to rope a dope it over the fence,,,,,,,the softer the weatherstrip, the easier it is,,,,,,IF you can find a glass company that guarantees they can install it without breaking that old, brittle, scratched, pitted windshield, go for it.....And the side and rear windows are the same procedure,,,,,unless they have that removable locking spline on it.
https://vintage-vans.forumotion.com/t1038p150-back-tovanagains-newest-65-chevy-sportvan-deluxe
- Post n°22
I took mine out of my 68 90. Just cut the rubber lip that holds the wind shield in and took my TIME! Just keep working around the windshield with a razor knife until it came out. I used a 1/4" piece of rope to put it back in and soapy water. put the new seal on the windshield first, then put the 1/4" piece of rope in the groove, then sat the bottom lip in and Slowly pulled the rope a little, pushed a little, pulled the rope a little, pushed a little, until it was in. Take your time! It was my first time too.
- Post n°23
Weatherstrip
Thanks for the valuable infos, parts catalog and parts numbers you have here. I will save them to my MS Excel for future references.
- Post n°24
Eagle1 wrote:I took mine out of my 68 90. Just cut the rubber lip that holds the wind shield in and took my TIME! Just keep working around the windshield with a razor knife until it came out. I used a 1/4" piece of rope to put it back in and soapy water. put the new seal on the windshield first, then put the 1/4" piece of rope in the groove, then sat the bottom lip in and Slowly pulled the rope a little, pushed a little, pulled the rope a little, pushed a little, until it was in. Take your time! It was my first time too.
So you were happy with the gasket? The one you ordered is $45 half the price of restoration specialties at $85. I need to get my order in soon.
- Post n°25
It is the same gasket as restoration specialties
