by itruns Mon Nov 22, 2010 6:46 pm
Here is Scottie's post on the A100 Yahoo Group forum (message # 30669)
there is a disc plate diagram in files for the plate. the rest of the conversion
is 87 dodge
dakota 4x4 front disc brakes. you need the caliber bracket, slide pins,
calipers, hoses, and
slip on rotors from the dakota. all you need from the a100 is the spindle and
hub. the
plate diagram is for the 11" spindle, you need to redrill the bottom 2 holes to
match the
10" spindle. a little grinding on the hub and caliber bracket is all you need,
71/72 dodge
van disc brake master cylinder was used. this setup has been in use on my 67
for over 4
years and never any trouble and stops great. anyone need help can email me.
scottie
This is the same guy that rigged up a 4 spd on the tree + reverse on the dash shifter.
