My 318 lost compression the other day. Several things happened but it had been running ok with a little smoke out of the breather. Pretty sure the head gasket went bad but the situation I am in is...
The engine is apart and it looks like besides the head gasket it probably needs to be bored out, it has about a .005 ridge in all the cylinders and while I have not taken the valves out yet it probably will need a valve job. In my area the machine shops generally want about 350 for the valve job and upwards of 800 to 1000 for the block which includes .020 over bore and new bearings.
I just want something to run good, not fast just reliable. Looks like from what I have found so far 1300+ for rebuild, 1700+ for long block or 850 for a used running motor from a mopar yard.
Any suggestions or ideas.
Thanks
Thanks
