Has anyone done it or tried it. Or recommend it. I want to get a good base down on the van to keep it tight and I know when I had my rhino lining done the stuff worked great. Thinking about doing that first before I install an interior. Any opinions out there. Thanks
+5
mrfoochie
bigblock666
9 posters
Rhino Lining the inside of a van
bigblock666- Number of posts : 27
Registration date : 2009-07-28
Re: Rhino Lining the inside of a van
bigblock thats my plans also, but not there yet. I'm sure it will work as a sound deadener also
Yeah. That wha I was thinking. Getting it done this week.
If you don't mind could you let us know what that sets you back
DanTheVanMan- Commissioner
- Number of posts : 7900
I am doing the walls floor and trying the roof. I want the textured stuff. The guy is calling me back tomorrow.
I'm also going to do the walls floor and roof, very interested in how much and how you like it
Told me 600 to do it. Roof, Walls, Floor and doors up to the seats. Dropping it off next week. I will keep you posted on the pictures.
mrfoochie- Number of posts : 24
Registration date : 2011-01-10
fellas, i see this is an older post but i was wondering how it went with the rhino as i too am considering it... does it stink?
I used it on my cab of my 69 IH cab after I replaced the floors. Inside and underneith. It smelled for a couple of weeks after but nothing horrible. I did it over the winter and it seems to be holding up well. I used the stuff from NAPA 100$ a gallon, you need a special gun to spray it on with. The only negative thing I can forsee is any future welding repairs will be dam near impossible.
Rayallen- Number of posts : 648
if you are thinking about doing this, id be certain that ive taken all precautions to prevent rust from forming under neath the lining. Id bring the floor all the way to bare metal and por 15 it.
mbasaraba- Number of posts : 823
Does this spray on with a regular paint sprayer? At $130 a gallon I would want to make sure I had the right stuff apply it right the first time.
Thinking of doing this to the whole bottom side of my van once I get it cleaned off. Also spraying the whole inside then a closed cell spray foam to fill between the ribs.
Matt, maybe you've already went thru this thread,
https://vintage-vans.forumotion.com/t10108-what-do-you-think
Personally I have a thing about doing anything that might make it hard to do repairs in the event of a mishap. I don't think we reached any kind of a consensus, but theres alot of food for thought. JM2C
Matt, I have sprayed the stuff before and it does not use the same paint sprayer as a home or auto, it uses a cheap undercoating sprayer. I think they are like $15 from harbor freight. and you’d need a air compressor.
the diy kits also allow for roll-on application.
sorta like this
http://www.amazon.com/AES-Industries-627-UNDER-COATING-SPRAY/dp/B001KW1LS2
and you’d need the plastic jar that screws on. those are pretty much disposable as the stuff is super sticky.
